Question about Goodman Heating & Cooling
Unit is frezzing on the coils - Goodman Heating & Cooling
  • 182 Answers
Dirty filter or low on charge is the usual culprit.
Posted on Aug 05, 2008
Fan runs on outside unit, but no air blows in the house
Listen for the motor if its sounds and thou its running it probably is, the indoor coil could be iced up, if so turn on the fan and turn off the cooling and let it thaw out. Check the air filter and coil that they are clean, setting the stat to low below 72 degrees would cause the coil to frezz as well. If motor is not running, it could be bad, but there are onther things that could be causing it to not run.
Jul 04, 2011 | Bryant Heating & Cooling
It frezzing up not getting cold i see the ice inside the window unit when i take off the filter
Either your not getting enough BTU's across
the evaporator ,because the system has a refrigerant
leak & it boils off too soon & freezes the coil or the
fan isn't working
Could have a bad thermostat but I doubt it
Jun 23, 2011 | General Electric AEQ12DM Air Conditioner
My air conditioner frezzses up sometimes. i got it tilted down on back side.some water drips out .but i wonder if i should take a plug out to let more water out to keep from frezzing up.
The freezing is caused by too little airflow over the evaporator coil or a low refrigerant charge. Make sure your air filters and the evaporator coil and condenser coil are clean. If the charge is low it may be cheaper to get a new unit than to charge an old one.
Aug 23, 2010 | Haier hwr10xc6 Air Conditioner
The air unit is frezzing up and the air is never under 70 degress in the house! whats making it keep frezzing up?
Hi, when the unit freezes up, it is either low on freon, a plugged a/c filter, or the evaporator coil is dirty and will need to be cleaned. When the evap. coil freezes up, the blower motor can't blow air through the coil. Check the filter, and behind the filter to see if the coil is dirty, just remove the screws to excess the evap. coil on this unit. Make sure the blower motor is running up to speed also. You will know. If the coil is dirty, try and clean it the best you can and replace the filter. If it continues to ice, you will need to have the freon level checked> These are the # 1 causes of coils icing up. Please let me know how it turns out.
A/C, Heating, & Refrigeration, Contractor
Aug 17, 2010 | Intertherm P3RA-048K Air Conditioner
The upper area were is not frezzing is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jul 15, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
It wont cycle on and off and is frezzing up
one of two things could be the problem. Check to see there isnt any blockage to the coils i.e. dirty, secondly, It sounds as if your unit is low on freon.
Jul 15, 2009 | Dometic Rooftop RV Air Conditioner
Rudd central unit frezzing up
One of two problems dirty filter. And if you don't have a filter dirty A-Coil. one solution second one Low on Freon which brings up another problem leak in system somewhere.
Nov 22, 2008 | Ruud Heating & Cooling
Suction line frezzes up every three or four dats
Check your air filter and evaporator coil if clean, but if its clean then may be the unit is under charge and need to recharge freon.
Mar 19, 2008 | Carrier 38CKC036 Air Conditioner
Air conditioner
Unit is low on Freon. Take it to a repair shop to find the leak & recharge the unit.
Jun 18, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Heating & Cooling Logo
19 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
