Question about LG Televison & Video
I have a lg dv1010 dvd/video player and cant get it out of safe code it appears to need 4 digits inputted?
Try 8888
Posted on Oct 28, 2008
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
LG DVD Player model:DV276 Regional code appears on my TV. Can I enter a code for me to view the dvd?
You need to make your player Region Free:
1. Using the remote control open tray :Press 0, 0, 0 (Region selection appears)
2. Select 0 for no region (ie. all regions)
3. Press pause button on remote control.
4. Turn Unit OFF and back ON again.
It should now be region free.
Jul 15, 2011 | LG Televison & Video
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
Mar 08, 2010 | GoVideo Go Video DVD/VCR Combo
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Setting the player to region free
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Dec 28, 2008 | Samsung DVD-M105 DVD Player
How do unlock the regional code on a LG DV1010?
Multi-Region:
Press the Open button on your remote control to open the drive tray
Place the DVD in the drive tray
Press the Open button on your remote control to close the drive tray
The onscreen display should indicate the message "Check Region Code"
Press Display, Menu and Play buttons in turn on your remote control
Jul 12, 2008 | Televison & Video
Unlock code for LG LH-T360
1. Power on the player with no disk in the drive
2. Press "PAUSE" on the remote
3. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display)
4. Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.)
5. Press "PAUSE" on the remote
6. Power the player off and then back on
Feb 27, 2008 | Audio Players & Recorders
Televison & Video Logo
194 people viewed this question
Computer Repairing
Computer Repairing
