Question about Gateway 4530GZ Notebook
Gateway 4530gz notebook
Will not power up. Hit power button and button will light up and I hear the fan but power will not remain on. If I hold power button down the power cycles on and off at aboout 1 second intervals. Does this with battery and or ac power.
  • Sparcus Oct 29, 2008
    I have a Gateway MX6446 laptop and it's doing the same thing! I was actually using it normally, then suddenly got a white screen with evenly spaced vertical lines. I switched the laptop off then powered it up after about 30 seconds and then that's when it started doing the rebooting cycle. Help, laptop gurus!!!
    Scholar:
  • 177 Answers
I'm sorry to say ,but I think it's with the motherboaed. Use the AC plug with the battery removed ,and see if it will power up. If not, I think it's a bad motherboard.
Posted on Jul 24, 2009
Gateway notebook wont boot up
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
Nv52 has the power light come on but no display or hdd light
cmos battery being charged. You can keep the laptop on to fully charge it or replace it with a new cmos battery.
Mar 15, 2012 | Gateway Computers & Internet
Drivers for Gateway 4530GZ
ok what you do make sure its a genuine copy then load internet explorer nad go on to windwos update and iff yu dont have a internet connection of any sort on it then go tohttp://support.gateway.com/support/drivers/search.asp?st=pn&param=4095 this should solve all your problems tht is all the driver s nown to man for that cmputer
May 24, 2009 | Gateway (4530GZ) PC Notebook
Gateway MT6451 Does not turn on
Probably the mainboard or flaky power supply.
I'd start by replacing the power supply. Buy one you can use in a new machine, though... or "borrow" one from another machine.
Mar 11, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
No display
this is boz of monitor is faulty.............try repaiirng at the service center..............Sameeraryan
Jan 12, 2009 | Gateway 4530GZ Notebook
I have a gateway m-6755 series laptop/notebook power issues
first press & hold power button for 6 second then again press power button to boot...
Dec 01, 2008 | Gateway M-6755 Notebook
Power problem
With this sysptoms u see the Processors of your system is faulty and that make your system when power on to flicker or to blink alone and switch off then you will have to replace the processor or if the processor is good then the processor Fan is faulty and it will need a replacement . bye ok
Rate this solution
You are always welcome.
Nov 06, 2008 | Gateway 4530GZ Notebook
Want to konw my memory capacity Serial NB24A 310 55747 Model 4530GZ
Memory type 333 MHz DDR RAM
Memory expansion options Two 200-pin industry standard DDR-SODIMM sockets
Accepts two 333 MHz DDR RAM memory modules in memory bay
2 GB maximum system memory
Oct 23, 2008 | Gateway Computers & Internet
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Gateway 450rog does not power on
Sounds like a voltage regulator. Have the system diagnosed at a repair shop. Sorry I know this isn't what you wanted to hear, but is probably the correct answer.
Jan 19, 2008 | Gateway 450ROG Notebook
Gateway 4530GZ Notebook Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
