Question about ASUS P4S333-VM Motherboard
I have a p4s333 mother board
My friend took his computer apart to put the mother board and all it's componits into another tower!, I can figure out the simple things but some of the wiring connecting to the mother board I can not figure out?. Do you have a photo of a wired computer to give me a rough idea how to wire this computer?.
  • Anonymous Mar 15, 2014
    took out mother board and subwoofer need to see connections
  • 56 Answers
Hey there
This is the sample picture of the M/B.
I hope this would help you a lot for reference.
Gimme acknowledge by rating me
Posted on Aug 04, 2008
How do I take apart the New Bright Power Horse Tower Crane TC36 to fix the tangled strings inside?
WOO HOO I FIGURED IT OUT!!!! You have to pull it apart from the base up. First thing I did was take off the feet. If you look down the tower potion you can see a screw. Then u took off the tower. I figured out that if you just lined up the black square portion it would have come apart with just the one screw. Anyways now there is 2 more screws to get. 3 total to take the new bright tc36 tower crane apart. They are hard to see, but once the base is off you can get at em. Good luck everyone.
Jul 09, 2012 | Garden
Hi, "Santa" was nice enough
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Jan 23, 2011 | Toys
I need the instructions to put the rose cottage together. Friends borrowed it an took the whole thing apart.
hi they can be found here
Nov 02, 2010 | Toys
Bose radio awrc1g only static like there is no antana. Works some times. CD works fine.
Mine did the same thing. I took the cover off and took the radio apart. I discovered the FM/AM tuning crystal was separated from the mother board (soldering failed). Anyway, when figured out where the crystal went I reinserted it and it worked great. I considered gluing it back in but opted to test my soldering skills and it worked out just fine. The crystal is a small silver electrical component with 2 prongs that plug into the motherboard.
Good Luck.
Oct 20, 2009 | Bose Wave Radio
I took a computer apart after it was beeeping and so i could check the mother board to make sure it was not burnt up and when i put it back togher now the montor and keyboard and mouse will not light up or...
So the beeping stopped?
Generally the beeping is coded with long and short beeps to tell you what is wrong. Often it signals a problem with the RAM but you need to look at the mother board manual to find out what it means.
It sounds like it does nothing at all now.
There are many easy mistakes you can make when putting a computer back together. It depends on how far you pulled it apart. Unless you are very observant when dismantling it you may have put a plug back on the wrong way around or something or missed a power cable somewhere.
You may have to take it to someone who knows where things go. It does not need to be a shop maybe you have a friend who knows about this stuff. Most of the common components in PC's all have the same rules about how they go together..
On the other hand it may have a broken component the beeps were telling you that after all.
Sep 20, 2009 | HP Compaq Presario SR1303wm PC Desktop
Akai lct2060 fell 8 inches to floor,wont power on
the ribbon can be replaced but be careful and use gloves to avoid contaminating the componite with the oils from your hands
Dec 18, 2008 | Akai LCT2060 Television
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Gateway hd2200 monitor
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Sep 28, 2008 | Gateway HD2200 LCD Monitor
Installing device in tower
If the linksys board that you are talking about is the WMP54g, the plug that you can see on the end of the board is for the antena.
Good Day
Mar 08, 2008 | Linksys Wireless-G WRT54G Router
ASUS P4S333-VM Motherboard Logo
222 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
