I have a Karcher K3.97 pressure washer. I think I'm losing pressure somewhere because the motor surges on and off every few seconds. No obvious leaks though. Could there be an internal leak through a diaphragm or valve?
  • patmoore Aug 24, 2008
    My machine is alse switching off and on when at idle. Works ok when washing. Im afraid it will burn out the motor
  • 92 Answers
Dear Sir(s),
The majority of power washers have a spill valve or sometimes called a Control Valve. This spill valve will contract when the gun is closed. As it contracts it switches off a micro switch. Also at the base of the spill valve, an opening opens to let water circulate. Now if this Spill Valve is defective, it will make the machine lose pressure and it will make the machine switch on and off also. I sometimes service the Spill valve and lubricate with special Silicon grease. But if the end of the Spill Valve is not closing correctly, then I suggest that the Spill Valve be renewed. To come to see the Spill Valve, you have to open the cover. Most probably you see wires or a thick wire attached to the head. The part attached to the head contains the micro-switch. Remove the Miro-Switch holder and then you might see screws holding the jammed or faulty spill valve. If you cannot pull the spill valve out, try attaching water and sometimes you can switch on the machine for a second...and with the pressure,...the spill valve will be spitted out.
The switching of ON and OFF due to a faulty Spill Valve, will for sure damage the capacitor. A damaged spill valve gives all these symptoms. Machine going on and off while gun closed and while gun opened, and added to these,... pressure gets less. One small other hint....if all is OK with the machine, and when spraying the machine goes on and off....this is due to a blocked nozzel.
Regards,
Fulltech.
Posted on May 27, 2009
My Karcher 11/5 U starts and stops when not in use
Pressure washers do this due to a valve called the 'unloader'. It's purpose is to relieve pressure from the pump when not in use so it is not under continuous strain, but there is also a pressure switch linked to the motor that will fire it up if the pressure drops to low so your washer is always primed and ready for action. This means tht the unloader relieves the pressure, then the electric pressure switch pumps it again to keep the pressure high. If it is doing it a couple of times a minute I wouldn't worry, but if it is every few seconds it would indicate to me that the pump is losing pressure constantly somewhere. Main reasons would be;
It could be a weak unloader, which is basically a strongish spring and a couple of plates and seals, but would normally come as a kit or complete valve.
A leaky seal in or around the pump. If this was the case you should see water leaking from the unit somewhere and then you could pin point the worn/damaged seal and replace it. Most washers have seal kits and it is advisable to replace seals in this way as it saves time later (especially if a worn seal, others will be wearing out too).
Failed non return valve. In the pump head there are normally two non return valves per piston (one directly after the piston and one a bit deeper into the outlet side) and also a couple in the back end of the pump head. These basically allow the pressurised water to be pushed through the pump and stop it flowing back into the cylinder set. If the water can flow back as well as forwards it will not keep pressure (like blowing a balloon up but not holding it shut between breaths). Non return valves will normally be supplied as a set and will be assembled already so just push into place when the pump head is apart. You would not see a leak if thesse valves are perished as the water will just flow back toward the source instead of out of the machine anywhere.
Sep 28, 2014 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
I have a karcher 495, it is puslating when it is
It sounds like there may be a pressure leak somewhere in the system. The machine cuts off when there is no flow of water past it. If it is leaking then there is intermittent flow. Which would make the machine run then stop continuously.
Nov 15, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
May 30, 2009 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Jul 29, 2007 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
1,387 people viewed this question
Top Washing Machines Experts
