Question about Nintendo GameCube Console
Controllers I have 3 controllers and NONE of them work correctly. One controller the R button gets stuck, but after awhile it will get unstuck. On the second one the A and B buttons dont work. And the third one is a wireless, it wont turn on no matter what you try (Already tried replacing batteries.) Please help!
Make sure the channel is the same on the wireless controller and receiver. wireless phones can also be at the same ghz and cause a problem
Posted on Aug 04, 2008
Hi, I did a system reset on my PS3 and now none of my controllers will not sync to console, Iv tried resetting controllers also. Could you help please ?
Make sure the controllers are plugged into the PS3 for initial use. Are the red LED lights flashing/lit. If not the battery may be dead. Can you borrow a friend's controller to make sure the controller ports are working correctly?
Dec 27, 2014 | Sony Playstation 3 (PS3) Console
Om dryer says control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Lock indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Jul 18, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
How can i fix my dryer. I it stuck on control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Locked indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Jul 13, 2011 | Whirlpool GEW9250 Electric Dryer
Error code E 68
A button is stuck and it needs to be unstuck. Enter key test mode during the diagnostic test mode to determine which keys is stuck.
Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control.
The buzzer sounds then immediately turn the cycle selector knob counterclockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds then the control enters diagnostic mode. The buzzer sounds 3 times and the LEDs flash.
Turn the cycle selector knob clockwise the second position from the top. The drive motor runs and the heat source turns off.
The buttons can now be tested. Press each button and the corresponding LEDs turn on. You should be able to find which button is stuck. The Options and Select buttons turn on the same set of LEDs and also the Cancel and Start/Pause buttons.
Access the control and unstuck the button. Disconnect power and remove the top panel by removing the screws attaching it to the rear of the dryer. Slid the panel rearward and lift it off the cabinet. The screws attaching the console to the cabinet are exposed. Remove the screws and disconnect the wire harnesses then remove the console. The control can now be removed and the buttons are exposed. Unstuck or clean the stuck button contacts. It is recommended to clean all other button contacts to prevent the recurrence of the same problem in the near future.
Oct 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Control lock light is on - The washer won't work. I unplugged overnight, and the light is still on when I plugged it in this morning. When I press Control On, HOld start, and Pause at the same time, the...
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle button. The control needs replacing if no stuck button is found and unlocking it is not possible. Please let us know if that is the case and if you need further help. Just indicate the exact model number of the machine.
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My PS2 controller does the same.
its vibrating because it is probably grounded.. check for stuck buttons...try opening it and check the rubber underneath the keys
Sep 06, 2009 | Sony PS2 Dual Shock 2 Controller...
Controllers don't work with full battery power
hi do you have any other wireless devices near by as the only reference i can find is controllers disconnecting because of wireless interference from another device.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 'A' button not pressing correctly
Open up you controller by removing the screws in the back (there's one behind a sticker) and clean up the buttons.
Jan 16, 2009 | Microsoft Xbox 360 Controller
Control locked
look for button with lock symbol beside it hold button 3-5 secs or until light go out
Aug 20, 2008 | KitchenAid KHWS01PMT Front Load Washer
Sticky Keys
you could allso try a short term solution which stops them sticking for between 1 hour and 3 hours at a time when they start to stick just rub a bit of water/spit around the buttons the part that dissapears into the controller when you press it this will losen the friction so it shouldnt stick intill it drys
May 20, 2007 | Microsoft Xbox 360 Controller
Nintendo GameCube Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
