Question about Compaq Armada 1700 Notebook
Laptop only runs in safe mode
Hi
I have a DELL Inspiron 2500 that I've had now for about 6 years - for some reason everytime I switch it on it will only run in safe mode. It tells me my local profile has been corrupted or deleted. I've tried setting up a new profile but this still hasn't solved the problem. Do you have any ideas how I can fix this problem? I tried to reinstal Windows XP but the problem is still there.
    Sergeant:
    Champion:
  • 256 Answers
Try loading drivers of you display it will solve problem....
Posted on Aug 04, 2008
Dell inspiron e1505
Hi, it appears the video card has failed. Dell uses a NVIDIA card which has a high failure rate. I do not believe it is the cable, screen or driver. I say this for several reasons. If it was the cable or screen there would be a problem with the boot screen showing. Also I have worked on Dells with this problem.
Dell lost a class action lawsuit years back over this issue. The two options are to have the video card reflowed or replace the motherboard.
Jun 27, 2013 | Computers & Internet
When I turn on my laptop it goes from the Dell Logo page to the black screen that says Windows Error Recovery. I've tried the steps they told me to take but nothings work I do not have the system
turn on your computer, and while its booting up, keep pressing f8 till you get to the dos screen, and choose safe mode. lets try to run your pc on safe mode
Mar 22, 2013 | Dell Inspiron 1545 Notebook
Blank sreen but laptop is running inthe back ground.
go into safe mode and just uninstall your graphic drivers and start again normaly
Jan 10, 2013 | Dell Inspiron 2500 Notebook
My problem is with a Dell Inspiron 8100 running Windows XP. at power on I recieve a screen giving options for: Safe mode, Safe mode w/network safe mode w/ command prompt. no matter what I chose, I recieve...
Hi
Thank you for your query
What you are explaining is a classic windows loop
Unfortunatley the only way around it is to reformat the PC
Please do the following
1) Simply put your recovery CD provided with your laptop into your DVD/CD rom drive and then allow the laptop to restart
Then simply follow the instructions on screen
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Dell Inspiron 8100 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
I have a dell 2500 inspiron that boots as far as the screen
You will need to check if there's a problem with the hardware, you will have to use the built in diagnostic for your laptop or if you have the drivers disc you can run the diagnostic there. Try to go to safe mode, if you can check the recent hardware or software changes you've made,you can try to reseat the hdd, try one memory at a time, though if you have memory errors, usually you will hear a beeping sound.
Oct 09, 2009 | Dell Inspiron 2500 Notebook
Dell inspiron 1525 memory test failure
Were you able to do a virus scan
try to get on in safe mode by constantly pressing F8 during restar select safemode
See if shutsdown in safemode
Do you here the fans running when it's on
You may just need to do a restore
Let me know what happens in safe mode
Jan 19, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Laptop works fine in safe mode but freezes in normal mode
Okay, easiest first. In Safe Mode, your sound won't work. Safe Mode means only enough drivers to make your PC more than a doorstop get loaded, so that's okay.
Second, if it boots to Safe Mode without difficulty, try running System Restore in System Tools. Go back to some date before when your issue started. That should get you going. Don't worry, your data files will not be affected in System Restore. I hope this helps.
Dec 28, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 1525 keyboard stop working - how can i fix it?
Try in safe mode:
Switch on the laptop and start tapping 'F8' key multiple times (especially when you get the dell logo.Locate safe mode and hit enter (by using the down/up error key).Open a notepad and check all the keybaord keys one by one and confirm if it works.
Test keyboard:
Switch off the laptop (if it is already switched on). Press "Fn" and power key together, this will launch a test (psa), wait for a message "where the color bars displayed",press 'Y' to continue the test. follow onscreen instructions till you rach a window with four options,(express test,symptop test,custom tes,,,,,), click on custom test and select keyboard, click on run test.....and confirm if keybaord works while running the test.
Regards,
Musheer.
Dec 07, 2008 | Dell F3534 Touchpad
Compaq Armada 1700 Notebook Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
