Question about Maytag Atlantis MAV6000 Top Load Washer
NOISE MAKES A NOISE LIKE A HIGH SPEED DRILL AS SOON AS WASHER STARTS WASH CYCLE AND CONTINUES TILL LOAD IS FINISHED
Sounds to me like something in the pump!!!!
Posted on Aug 07, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
During the spin cycles in the wash the machine makes a loud whining noise while spinning? As soon as the cycle is finished the problem goes away. Is this a faulty belt or what. Please help.
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Apr 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Bad noise at begining of rinse cycle.
It sounds like your gear case (transmission) has gone bad. If the washer fills and agitates that tells me that the problem cannot be with the motor coupling and drive motor. It also rules out a pump problem if the washer completes a wash cycle and drains properly. The only thing left is the gears inside the transmission. Sometimes they go bad in a way that portions of the wash will work while others don't. The part number is 3360629 and the price usually runs about $150. I hope this may help you in some way.
Sep 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
