D Link DP 301P+ printer server
I have pinged the address of the printer server and recieved no errors. I have connected the printer directly to the computer and it prints without any problem. My problem is that when the print server and printer are connected I cannot print. I have also reset the printer server.
THanks
Vince
  • Anonymous Sep 24, 2008
    I have the same problem. How can this be!!!
  • 3 Answers
Go to Advanced settings and Disable UPnP.......where it will be available ....give clear information
Lee Lakeside IT
Best IT copany it the UK..... maybe the world!!!!
If only we did larger
Posted on Dec 14, 2009
I no how to fix this...
go to Advanced settings and Disable UPnP
Lee Lakeside IT
Posted on Sep 24, 2008
Change ip address
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
Aug 17, 2013 | D-Link DP 301P (DP-301P) Print Server
I have connected the d-link to a KOT printer,my network cannot find the server.And according to the manual I cannot browse the default ip of the DP-301P+ sever.please assist me immediately.
I have D link DP- 301P Print server I am using it in Epson M188D Printer for KOT Printing but its shows some times printer not found on network, please help me to solve the problem.
Ajay
Mar 22, 2011 | D-Link DP 301P (DP-301P) Print Server
I have print server DP-301U Pls let me know the default IP address for configuration
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Feb 09, 2011 | D-Link DP 301P (DP-301P) Print Server
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
How to reset the administrator password of the D-Link DP-301P+
hi
i forgot password Printer Server D_link Dp-301p
Please Help Me
Jul 30, 2009 | D-Link DP 301P (DP-301P) Print Server
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
No printing threw terminal service
do you have the options set correctly on the remote computers assistant to use local devices
Dec 25, 2007 | D-Link DP 301P (DP-301P) Print Server
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Open Questions:
Computers & Internet Logo
1,327 people viewed this question
David Payne
David Payne
