You need to completely uninstall the drivers/software that you have already installed.
To do this:
Start --> Run --> Type: 'appwiz.cpl' without the quotes.
Inside of the Add/Remove Control Panel, scroll down and search for anything that has the name of the company/software/scanner in it and REMOVE IT!!
After removing the software and drivers you need to go to the manufactures website (like you've already done) and just make sure you have the most updated software/drivers (FOR windows 7!)
If you don't remove the software and drivers first, it will cause complications...which I assume is what you've run into. Good luck!
Thanks and rate if this helps you!!
Win7 will need a driver from the MS website for your scannner...for that u need to register with MS and get the driver
do an update for Wn7 after regiter with MS
