Question about Epson DFX-9000 Matrix Printer
Dfx9000 Hi I changed a board on a dfx9000 and the printer is working fine but nothing is showing on paper as it prints. The ribbon is new the ribbon mask is new i have gone inot the menu and done a manual pg adjustment with no luck if you put it on auto adjust still no joy
  • Anonymous Aug 10, 2008
    I still have the same problem even after adjusting the print gap. I also have another dfx9000 coing up with error 13
    Would be very grateful if you can help
    Genius:
  • 1,447 Answers
Hi-
Have you tried adjusting the platen gap, run a selftest on the unit and if doesnt print/if you are getting a blank page still. you have to adjust platen gap- check the setting as well on the panel try setting it to default.
Posted on Aug 04, 2008
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
When the print work in some time the head scratch paper
There's an aluminium plate between the ribbon and the paper (ribbon mask) which is probably cracked and you may need the replace it.
Apr 19, 2012 | Epson DFX-9000 Dot Matrix Printer
Epson dfx9000 ribbon jam errors
There is a sub-board under the carriage assy. that controls all the functions. It has probably gone south.
Nov 28, 2011 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Will print on sticker labels, but not on thick price ticket paper
If you are not using ribbon, the tickets are probably not Direct thermal. Try using a Ribbon and see if it works
Mar 02, 2010 | Zebra 105SL Thermal Label Printer
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
Printing very slow
check the printer on a different computer
Aug 27, 2009 | OKI MICROLINE 520 Matrix Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Lq-2180 continous blinking
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth so that it makes contact on both sides forcefully enough to make a loud noise. Reload the ribbon and the paper and try your test again.
Dec 07, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson DFX-9000 Matrix Printer Logo
321 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
