Question about Magellan GPS
Magellan maestro 4250 power connection loose. how do i get the back off?
I took the 2 tiny rubber plugs out of the black part of the case, and underneath them were small screws. I removed the screws and used a credit card to pry open the case. The credit card helps snap the latches around the inside edge of the case. Finally I used the credit card to pop the double tape seal inside the middle of the black cover. All of this, only to see that the power connection wasn't loose but detached from the circuit board. Even if I fixed it, it appears to be a very poor design for something that needs to be unplugged frequently.
Posted on Aug 05, 2008
SOURCE:
Magellan 4250 fails to turn on. Have tried both car and home power supplies with same result. Its as if unit battery is bad.
hi depending on how old your system is its probably just your battery that needs replacement ,though it should work while connected to power source check the power inlit make sure it is not damaged or broken goodluck
Mar 18, 2011 | Magellan Maestro 4250 GPS
How do i open my magellan gps-maestro 4250-to get a broken screen out?
there are 4 screws hidden under the little black rubber plugs on the back of the unit...remove those 4 screws, then slip something small and flat (i use my finger nail) around the area where the back and front of the case meet...there are several snaps that hold it together that youll have to break loose to seperate the back and front....slowly seprate then and disconnect the screen ribbon from the main board...
the screen is only held in by little clips on the sides...just gently pull the case away from the screen in those areas and the screen will pop out
let me know if you need further help
May 15, 2010 | Magellan GPS 315 GPS Receiver
Just wondering how can i do the up date for my magellan maestro 4250 gps for free
new up date for magellan 4250 just go to www.magellangps.com and click on unit gps thann download the f/m version 4.86 it is free and simple juste follow the step by step body good luck
Mar 31, 2010 | Magellan Maestro 4250 GPS
Broken screen on Magellan Maestro 4250
Even though it is not in warranty,you can send it back to factory for repairs,my friend had his Magellan screen replaced for $80 last year.
Aug 18, 2009 | Magellan Maestro 4250 Car GPS Receiver
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
I HAVE MAGELLAN MAESTRO 4250 AND TOUCH SCREEN IS NOT WORKING WHAT CAN I DO THANKS
I got the touch screen from ebay, with search key word "4250 digitizer".
May 26, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 needs a battery
There is a kit that includes battery, tools, and how-to video available here.
May 22, 2009 | Magellan Maestro 4250 GPS
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
GPS Logo
85 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
