Question about Olympus FE-230 Digital Camera
Lens not opening
Battery fully charged when the camera is turned on the motor makes a noise as if it is going to open but fails to do so
  • mamausa32 Aug 12, 2008
    i had the same problem,in service somebody told me its sand in-i paid 140$ for clean it up -steel don't work well,now its noisy,battery cover is loose(opening every time when i trying shoot)-im so stupid:))) never bother fixing anything.....
  • garylavan Aug 16, 2008
    I purchased new FE-230 this year and I keep it in a case. The battery is fully charged and when turned on the lense opens and closes several times then turns off. I have manually held the lense open and then turn camera off and back on. It will sometimes operate correctly for several days then do the same thing happens again.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
If your battery is fully charged, then it would need to go to repair
Posted on Aug 22, 2008
2 Suggested Answers
SOURCE:
t00nz
  • 4738 Answers
SOURCE: Olympus X-920 camera lens fails
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Posted on Jul 02, 2011
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My camera comes on and then the lens retract and go back into the camera. The camera never fully comes on. The batteries are fully charged and there is plenty of memory. Please help.
Could be one of the ribbon cables is loose. If you can open the camera and reseat all the ribbon cables. If the lens makes an ugly grinding noise the gears to the lens are chewed up. You can go to esupport.sony.com for a flat rate repair quote. Hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony DSC-W230 turns on and lens keep opening and closing, and then it shows "turn power off and on again". how do i fix this ?
This sounds like a stuck lens. Here is a good blog about things to try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog is about a lens error, but when the camera lens opens and closes, there is often a problem with the lens.
Also make sure the battery is fully charged, and good. Also make sure the contacts are clean on the battery, and also inside the camera.
If all fails to get it working again, get an estimate on repair first, since the cost can justify just going ahead and buying a new camera.
Good luck, and hope this helps.
Aug 01, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Camera turns on but stops halfway through loading process
Hi there just like to informed you that 2 reason can make the issue.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise or open only half way.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Nikon Coolpix 4600 Digital Camera
My Camera's battery is fully charged, but when I try to turn it on, it makes a noise, lense opens a little bit and screen flickers a small bit? Any ideas?!
It sounds like your lens is out of alignment and dragging. Check to see if there is any debris caught around the edge of the lens. Other than that, a repair or replacement may be necessary.
Mar 22, 2010 | Canon PowerShot SD950 IS Digital Camera
Lens won't close
Please charged your battery fully & then try. If same thing going on then i say ,Yes its a problem of internal zooming function. Some slot is damaged or dislocate & your camera motor make noise. Its need service & after that it will work.
Look at this picture, you will see then what place is damaged.
Feb 06, 2010 | Polaroid i737 Digital Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Turns on beeps lens comes out tries to focus
HI, this will occur when there ia a lens mechanism failuer. Inside the cam housing , there is a mechanism that is powered by a small servo motor. this mech can become lose or unstable, in return, jamming itself open or closed. When this happens, you will need to send it to the manufacture for this repair. they will replace the motor and mechanism as well. Contact Pentex for a repair ticket. they will refer you to a nearby repair depot.
Jun 10, 2009 | Pentax Optio E40 Digital Camera
Casio EX-Z55 wont turn on after lens error
A lens error is something that can only be fixed my sending in to the repairs department. There is nothing that can be done at home to fix that.
Nov 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Olympus FE-230 Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
