Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Baseboard heater connect
I have the same problem, i have a 240 volts fahrenheat electric convector baseboard heater, i would like a diagram of the wiring, with the termastat. plz e/mail me at kaclark@zoominternet.net
    Scholar:
  • 68 Answers
A longer explanation is needed on these questions or I am not finding the whole question. I volunteer on allexperts.com and it is much clearer what help someone needs. Write to me at wbwill@sbcglobal.net or through allexperts.com and I will help you wire this. A baseboard heater should not be that complicated to wire up.
It should wire up like a 240 volt dryer, with the proper wire size and proper double pole breaker.
The heater will have the amperage and voltage rating on the unit, take that information and then measure how far from the breaker box you will be, to a hardware store. They can tell you and sell you the wire and breaker. aLSO TELL THEM WHAT BRAND BREAKER BOX YOU HAVE, it is written on the box somewhere.
The wire size will determined by the amps and the distance, the breaker will be sized to protect the wire, there will be either 2 hots and a neutral, or 2 hots and a neutral and a ground, older 240 devices were all three wire, now days most are four, the hardware store can tell you. You might have a red, black and white and green wire. Red would be one hot lead, black another hot, white neutral, green ground. The device will have either have the wires in a connection box or lugs labeled for hot, hot, neutral and ground. One way you wire nut the wire to each, the other you place under the lugs, at the breaker the hots are both ran through their own breaker, called a double breaker, the white will go on the neutral buss, and the green ground will go to the ground bar.
Hope this helps, it should not be a difficult job. or write me at wbwill@sbcglobal.net
Posted on Nov 15, 2008
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
I am puchasing a 28 YO home with electric baseboard heating. Will this be satisfactory or have there been much advancement made in baseboard heating used today?
To put it simply; any other heat source is better than your existing baseboard heaters. Yes, there have been sincere advances. Here is an informational website:
http://www.heater-home.com/FAQ_baseboard.aspx
Hope this helps some:)
Farmerbear
Aug 30, 2010 | Fahrenheat Electric Convector Baseboard...
I need a manual for a farenheat F2345nwc baseboard
http://www.marleymep.com/Develop/prod_pdf/2500wiring.pdf
i think this is the same parent company
Oct 10, 2009 | Fahrenheat Electric Convector Baseboard...
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
Where can i purchase switch for farhenheat baseboard heater?
remove the switch and contact either Grainger's or Johnstones and they will cross reference the switch.
Oct 05, 2008 | Fahrenheat Electric Convector Baseboard...
Please i need help with 240v wiring to heater
i have the answer, i just did mine...though u already have your answer since this post was published a while back ago...if not write me back...
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Black stuff on walls
your walls are trying to burn good thing you cannot turn it down it can kill you.
Jan 03, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
661 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
