TechnoMarine Abyss ABS01 Watch Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My watch has stopped working intermintently, does it contain a battery which requires replacement? Also, I do not have a manual for it, is there one available online. Thank you for your kind consideration to my questions. I look forward to your immediate response.
Anonymous
Level 3:
President:
  • Master 2,080 Answers
  • Posted on Mar 29, 2011
Anonymous
Master
Level 3:
President:
Answers
2080
Questions
Helped
927670
Points
6465
Yes it has a battery that will need to be changed every few years.
Click on the following link for details:
http://www.righttime.com/rt/technomarine/abs01.htm
Just take your watch into any jewellery store and they will change out the battery for you for around $10 parts and labour included.
Good luck.
My Invicta reserve speedway won't keep time but the stop watch works need help
If the stopwatch is working but the timekeeping is not accurate on your Invicta Reserve Speedway watch, there could be several possible causes for the issue. Here are some steps you can take to troubleshoot the problem:
  1. Check the battery: A weak or dying battery can cause timekeeping issues. Try replacing the battery with a fresh one to see if it helps.
  2. Check the movement: If the battery replacement doesn't solve the issue, the movement (the internal mechanism that powers the watch) may be damaged or worn out. A professional watchmaker can diagnose the problem and repair or replace the movement if necessary.
  3. Check the setting: Make sure the watch is set to the correct time and time zone. You can refer to the manual or instructions for your watch on how to set the time and time zone.
  4. Magnetization: Sometimes, exposure to magnetic fields can interfere with the timekeeping of a watch. If you suspect that your watch has been exposed to a strong magnetic field, take it to a professional watchmaker for demagnetization.
  5. Water damage: If your watch has been exposed to water or moisture, it can cause damage to the movement and affect the timekeeping. You can try drying out the watch and replacing the battery, but it may require professional repair.
If none of these steps resolve the issue, you may need to take your Invicta Reserve Speedway watch to a professional watchmaker for diagnosis and repair.
I have a Movado Series 800 Subsea. It stops running when it's not worn. If I shake it, it starts up agin. I know it's a quartz hence a battery. Is it kenetic? The manual does not say.
It is not kinetic, the watch should run whether it is worn or not. A kinetic watch requires motion in order to wind a mechanical movement. A quartz movement requires a battery and that is all. You might want to change the battery.
Feb 17, 2014 • Watches
1helpful
My watch stopped working. I think I just need to replace the battery in it. how do I get the back of the watch off to do that?
Bulova Accutron watches were originally designed to use Mercury batteries of 1.35 volts, since they were the only type manufactured then. The pic (left) shows an original 214 all-metal "top hat" cell, before 387 cells with the plastic spacer became available. In most areas of the world, mercury-based batteries are no longer available, due to environmental concerns related to the safe disposal of them. The Tuning Fork watches manufactured by Esa (e.g the f300 Omega) were designed to run on either mercury or silver oxide batteries without any adjustment, provided the last repairer to work on the watch set up the index mechanism according to factory specifications.
It is strongly recommended that you do not replace batteries yourself, as special tools are required to open the watch case without damaging it. The only exception to this is the Accutron 214 model, which has a small battery hatch on the back.
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
New battery installed, ran for a few hours and stopped. replaced with another new battery and still not running
Try connecting the case of the battery to the chassis of the watch (use a pair of tweezers).
This seems a common requirement for new battery installation and may apply to your watch.
Mar 19, 2010 • Watches
1helpful
2answers
My watch, Seiko Kinetic Auto-Relay (5J22-OD60), no longer holds enough energy to keep working overnight, the second hand starts moving at two-second intervals and it stops before morning.
You have a bad capacitor. You can either try to repair this yourself with a special upgrade kit for about $20 (and maybe screw it up) or pay an expert who will do it right for $67.
http://www.qualitywatchrepair.com/seiko_kinetic.htm
For an extra $20 he'll do a pressure test on it to be sure it is water-proof but since this is a pro you really don't need to worry about it on a non dive watch.
Sep 29, 2009 • Watches
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
Swiss army stopped, im stressing..
If it's a quartz (battery powered) watch test the voltage of the battery. If below 1.5v then replace with new. Ensure battery contacts make good contact with the battery and are free of corrosion/rust/contamination of any sort. Check operating manual for any specifics regarding battery replacement proceedure.
Jul 26, 2009 • Watches
2helpful
2answers
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Top TechnoMarine Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
