Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony - no power
I have a Sony model# KV-36FS120 that will not turn on. The LED light is flashing 5 times. Can you offer any suggestions to fix?
  • gina7716 Aug 06, 2008
    i have the same exact problem. my tv is only 3 yrs old!
    New Friend:
  • 76 Answers
Well 5 times blinking indicates EEPROM ic getting malfunction. Change this ic tv is working well and good. Note that this ic comes only in blank you have to program it as your tv model.
Posted on Aug 15, 2008
TV won't turn on. I've got 5 flashes on the standby light. KV-36FS120, Dec 2004 BA6 Thanks!
check video out section,Q705,Q732,Q761 on C board,check Q219,Q218,Q220 on A board,but it could be in IK blanking turn up the screen a little.hope this helps.optain parts at Mats Electronics #1-800-628-1118
Feb 12, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-32HS500 WON'T TURN ON standby light flashes 7 and sometimes 6 times and has flashed 4 times also.
These are sony error codes while in protection mode. The 7 blinks means high voltage exceeded 33k volts ,caused by either horizontal or power supply circuits.
The 6 blinks code is for no horizontal deflection, and the 4 blinks code is for no vertical deflection.
So the one thing they all have in common is the power supply that will need to be repaired before you can use the set again.
Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 02, 2009 | Televison & Video
Red light flashing
DO NOT under any circumstances touch the red wire inside the set. This cable connects to the picture tube and carrys 33,000V and can cause injury. The 3 blinks are a diagnostic code that indicate the defective circuit. Please confirm the model number as KV-36FS120 and I'll look up the code.
There is no Lamp door if this is the KV model mentioned above as this is a CRT based set not a projection set.
Please confirm the model number so I can get you a proper solution.
Sep 11, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony tv model # kv36fs320 no picture sound is there. Standby timer red light flashes 5 times.
The power seems ok as it was working fine this morning had kids channel on for my daughter for about 1-2 hours while I was pottering about cleaning then daughter told me TV had gone black
May 15, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron 36 will not come on but led flashes 5 times quickly
yeah, this are the circuits that you have to check,horizontal ckt.and the vertical ic it might be bad you need some electronics repair skills in order for you to do this.
good luck
Oct 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Trinitron 36" led flashes 11 steady flashes then 5 quick.
You have defective power oscillation in power circuit! this need to diagnose to find the bad parts!
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
