Question about Toshiba A75-S125 Satellite Notebook
Hard drive clicks + error appears on screen when turned on
When i turn the computer on the hard drive automatically starts clicking.
Also this error appears on the screen:
intel undi, PXE-2.0 (build 082)
copyright (C) 1997-2000 Intel Corporation
For Resaltek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media Test Failure, Check Cable
PXE-M0F: Existing PXE ROM.
And it just keeps repeating that.
And also i put the system restore disk in, and click ok, then continue, but nothing happens, it doesnt restore...
  • dc4teggy Aug 04, 2008
    it was in secure, so if my hard drive needs to be replaced, it is causing all of these other problems?
  • Anonymous Feb 09, 2009
    same but on acer
Dude, try to go to your bios then, look for pci lan.....
disable it... your computer is trying to boot to a network
through your lancard... let me know if i was able to helped
you....
Posted on Sep 01, 2008
    Sergeant:
  • 152 Answers
I would check to make sure the hard drive is in secure and if it is I hate to say it sounds like your hard drive needs replaced.
Posted on Aug 04, 2008
  • xalint1
    xalint1 Aug 04, 2008
    There is a couple more things I would look at before you purchase a new drive.Go into the BIOS settings make sure your first boot device is your hard drive then try to restart and then if that doesn't work change the first device to CD drive then hard drive as your second boot device then try the restore disk.If you are using XP reformat drive using NTFS setting.Let me know how it goes I may be able to help more.
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Tip
How to maintain your hard drive and check for bad sectors and errors
  1. Go to the Start Menu and choose My Computer
  2. Right click on the drive you want to check. I always check C: drive as it is my main drive.
  3. Choose Properties from the drop down menu.
  4. Click on the Tools tab
  5. Here you can press check now to scan your hard disc for errors.
  6. A box will appear with some choices. Choose to let Windows fix errors automatically.
  7. Then press start.
  8. When it is finished scanning a report will appear.
on May 16, 2010 | Computers & Internet
Tip
My computer is running slow
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
on Apr 06, 2010 | Computers & Internet
Cyclic redundancy error
I cannot remove a sandisk drive that has a camera disk 4GB. The drive alternates between being lit and unlit. When lit, it does not appear in My Computer. When unlit, it appears in My Computer but if I try...
right click in the bootom toolbar (bottom of screen) right click select task manager applications also processes if you see something running that does not need to be or is running on your scandisk select end now
also you could run chkdsk utility click start double click on computer in the right panel to open you should see your drive or
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope it helps
Jul 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Ihave amercury pi945gcm please till me how can I dellete the information appears on the screen when I turn my computer on and makes my computer turns on without showing the features of the the main...
if the imformation are desktop icons(short cuts) right click on them select delete
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
May 08, 2011 | Mercury Computers & Internet
Error showing on my screen with the status code 13030, I try to close it , but it appears on the screen over and over.
13030 error are usually caused when the operating system's registry contains errors or when certain system files are missing or broken; 13030 error problems are a sign of a very unhealthy system. 13030 error are caused in one way or another by misconfigured system files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
do not do anything while the chkdsk utility is in progress any input will damage your computer
hopethishelps dont forget to vote
Feb 22, 2011 | Computers & Internet
Computer froze i tried to shut down wouldnt then i tried system restore..started system restore then computer shut down...now when i turn on only black screen appears. went in bios to boot said boot device...
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Computers & Internet
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
10.Update Windows
PS Please Note to leave a positive note.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
Toshiba A75-S125 Satellite Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
