Question about Pioneer VSX-D514 Receiver
How do I program the 2 component video inputs?
How do I program the 2 component video inputs so that the sound/video coincide?
  • mugenwallace May 10, 2009
    I am trying to set up one of these receivers for a friend and i cannot get the video output to work for the component hook ups or get the digital audion to work. I do not have a manual so i am kind of lost of what to do, the receivers i use are set up completely different
    Problem Solver:
  • 6 Answers
On the remote control, push the left arrow button to display comp1, then the up arrow to display the correct video setting. push the left arrow again to display comp2, then the up arrow again to select the correct video setting.
Same procedure for digital audio (coax1 and coax2)
Posted on Aug 05, 2008
Hi i have play station 2 and i don't know what to put the tv on to play my games
Well first if you don't have a factory remote you will have to purchase a universal remote that supports i'll products program using factory codes or do a manual search( which takes a little time but I have had better luck with for more functions ) after programming you press tv/vcr button in which it should display ant. vIDEO1 video 2 and component repress button until desired chann el is highlighted coincideing with whatever location you have your device connected rear is video 1 and multicolor is component and front is video2
May 18, 2011 | iLO IWT3206 TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Can I get surround sound while watching TV programs with this system abd if so how do I connect to TV
Yes, IF your cable or satellite box has an optical digital audio out connector...
Page 10: "Connecting a digital component"
http://www.retrevo.com/support/JVC-TH-S3-Home-Theater-Systems-manual/id/318ag405/t/2/
NOTE
When playing a video component such as a DBS tuner or cable box;
• To listen to the sound, select "AUX DIGITAL" as the source to play.
(See page 14.)
• To see the picture, connect the video output jack of the component to
the video input jack of the TV directly, and select the correct input
mode on the TV.
Dec 28, 2010 | JVC TH-S3 System
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
http://bit.ly/2ykOBno
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
How to program the autio vidio inputs for zenith tv
Hi cathie
If you have sound it means that the tv is in aux/video mode.
Now make sure that the video output of the vcr is connected to the same aux/video input that has the sound connected to. i.e input 1 or 2 .
Also you want to try and switch with another cable to make sure that the cable you are using now is o.k.
Another way to try the tv input would be to connect something else in that input(cable box ,dvd ,video game etc,)
Try it and let me know.
Feb 02, 2010 | Televison & Video
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
I have the HT-S3100 model, and hooked up my tv, xbox360, and Wii to it. The audio works for all three, but the only video I can get is for the xbox. I am using the component hookup and it is hooked up...
On all tv's there should be independent input for all devices. Xbox 360 ,Wii, and tv. Take a look at input at the back of tv. The Xbox input should coincide audio/video. The same with each device. Then you use the tv's remote to select the input for each device. They should all work independently from each other. Such as component 1 for Xbox, component 2 for Wii, and depending on what type of tv input you use, such as coaxial, RCA, you note and put tv input setting on the device that you are going to use. If you have the audio working on each device, check the video input for each device. Make sure they correspond.
Oct 13, 2008 | Onkyo Audio Players & Recorders
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Pioneer VSX-D514 Receiver Logo
88 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
