Question about Xerox Office Equipment & Supplies
HI, I have a Xerox DC240 that has an error code 093-317 and I need to get a job out tonight. Can any one help.
The following procedure is exclusively only for error 093-317.
I don’t responsible of malfunctioning or wrong procedure.
-Push number 0 for 4 seconds and without release 0 button push green buttun (big green copy button) until appear a window with a password request, insert right password (on my machine is 6789) and give the ok.
Push the botton with a little key’s image.
Select Setup System
Select Common Setup
Maintenance (servicing) and diagnosis
NVM write/read
In CHAIN WRK insert 762-315 and confirm
When appear a numver in value field otherwise than 0 (ex. 3)
In New Value inser 0 and save
Close
Exit
Yes
Enjoy!!
Posted on Jul 07, 2009
  • syedhussain Sep 23, 2013
    hello sir, this is not work can u please say some other way to clear error 093-311 for workcentre 7232
    President:
  • 2,072 Answers
Try replacing the Xerographic Module, if that doesnt work then the donor roll in the developer housing is bad.
Posted on Aug 04, 2008
Xerox dc240 error code 127-337 problem solution
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Jun 26, 2016 | Xerox Office Equipment & Supplies
Solution to solve error 010-320
We used to get lots of these messages on our DC240 & were told it was a room temperature issue. The following worls
10-320 error
DC 240 error, Caused by fuser being too cold
1) Press & hold "0" for over 10 seconds
2) Whilst keeping hold of "0", press START
3) Password is 6789, Confirm
4) Press key shaped key on keypad
5) System Settings
6) Common Settings
7) Main/Diagnostics
8) NVM Read Write
9) 744 350 Confirm/Change
10) Enter "0" into New Value, Save
11) Close, Exit, Close
12) Reboot
Apr 09, 2013 | Xerox DocuColor 3535 Copier
Fault code 127-337
Xerox dc240 error code 127-337 problem solustion
Aug 06, 2012 | Xerox DocuColor 240 242 250 252 260 Black...
Driver doesn't recognize finisher pro on xerox dc240
The new Windows operating software and some other Windows OS may not work with older devices. Call Xerox for a driver compatible with the Windows you are using.
Mar 25, 2012 | Xerox Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Error code 016 781
The 016-783 error message indicates that “Cause – Could not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the scans in had previously been deleted, so I had recreated the shared network folder. What I had neglected to do though was to recreate the sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup referenced in the job template I had no more error codes with that scanning job template.
Jul 01, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox Phaser 7400 displaying error code u60. Even after rebooting.
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Dec 17, 2009 | Xerox Phaser 7400/N Printer
1,221 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
