Question about RCA 25404RE3 Corded Phone
My # comes up restricted
My number comes up as restricted when I call people with caller ID. I work for a school district and don't want my calls restricted. The phone company says it is not restricted on their side and it must be a function of my phone. The manual says nothing about it. I have an RCA 2540RE3 executive series
I called RCA (Thompson)
Posted on Aug 05, 2008
SOURCE:
Droid z992 shows restricted number rather than my name on recipient phone. How do I fix this.
Caller ID blocking feature may be on go to Settings and then tap on Call on a android phone
From there, tap on Additional Settings and in there, tap on Caller ID
just set the Caller ID to show Number" and it will be unblocked
Oct 03, 2015 | Cell Phones
How to block a particular number from calling our casio ravine cell?
There is no option on this phone to restrict the caller ID.
If the number is XXXXXX up as 'Restricted' then it can only happen if you dial *67 at the beginning of the number you want to call to block you caller ID information. Or, you can also call Verizon and have caller ID blocked for every number.
If this is happening for every number, then you will need to call Verizon and have them deactivate the caller ID restriction.
May 29, 2014 | ooVoo
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
Describe your AT&T Blackberry
There are 2 places this can be set, and with AT&T, it tends to be set at the network level. Meaning to turn it off, you have to call them and request that they disable caller ID block on outgoing calls.
Jul 26, 2009 | AT&T Blackberry Curve 8300 Smartphone
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Apr 20, 2009 | Motorola Mobility Moto Q
I m getting a call from a unknown number ..he is bothering me and my family ..how can i get the name of that user...please help!!!
The person that left the "Solution #1" is incorrect. You can go to a website called Trapcall.com and set your phone up so that you can find out the number of the unknown caller. Unfortunately there is a small fee associated with this feature and it also disables your voicemail. I think it is worth it to have a solution for a troublesome caller.
Apr 13, 2009 | Cell Phones
Cannot phone Canada
I had the same problem.
The way around this is to dial the number with one of the following codes in front of it:
*67 or *82
Dialing *67+1+(Canadian Phone Number) <SEND> will make the call to Canada, however, your number will not display on the caller's Caller ID display.
Dialing *82+1+(Canadian Phone Number) <SEND> will make the call to Canada, AND your number WILL show up on the caller's Caller ID Display.
I tried it with my Motorola W375 and it works like a charm as of February 13th, 2009.
Dec 08, 2008 | Motorola Mobility W375 Cellular Phone
A restricted number keeps calling me, how do i see who it is?
There are a few services that make it easy to find the real number of a blocked or restricted caller. They do cost money (some as low as $5.00 per month to unmask numbers) to use with your cellphone.
You can even get the name and address of a blocked caller. Check into caller id unblocking services. Hopefully that will help you out.
Unblock restricted numbers with Trapcall's Bug Trap
Jul 18, 2008 | Lands Phones
RCA 25404RE3 Corded Phone Logo
798 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
