Question about Durabrand DWT1304 13" TV
OWNERS MANUAL I do not have an owners manual. I do not know if it is possible to connect this TV to a cable outlet and if possible how?
    Champion:
  • 232 Answers
Durabndrand is manufactured by lenoxx, check out there site and contact them they are ur best source of help the manufacture themself.
http://www.lenoxx.com/2005/products.htm
Thank You!
Posted on Aug 04, 2008
I have a Palsonic TV model 4878. It has no av outlets. How do I connect it to my set top box? It appears to have what looks like a SCSI plug...
Please review your Owner's manual. and or your set top box. Ask your cable? supplyer customer service and or your set top box
Owner's manual.
Mar 18, 2015 | Televison & Video
I have a blu-ray disk/dvd player. I'm not connected to the internet. Can I play a DVD, yes however I have no sound. What am I doing wrong? TV is just an old regular one. Thank you, Julie Berriman
without knowing the brand and model of the cd-player and your tv, there is virtually not possible to answer your question.
what connection is between tv and player?
hdma? sound will be fine automatically, if no sound, check cable connection and select appropriate source on your tv, but if you have pix and no sound - we can safely assume that this is not...
coax? same remarks like for hdma
any other connection require more than single cable or special configuration... too many possibilities and you did not give a chance... no brand and no model...
i would suggest going to the tv and dvd player manufacturers site and check they respective owners manual
Jan 15, 2015 | Philips Televison & Video
My son bought this for me, and he has taken the user manual (if there was one) to New Zealand with him - he lives there. Can I obtain another manual? I don't know a) how to charge the battery and b)...
Here is your Owner's Manual:
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
To Charge Your Nuvi:
  • Connect the vehicle power cable to the mini-USB connector on your nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for the nuvi to charge.
  • Connect an AC adapter (optional accessory) to the nuvi and a wall outlet.
  • Connect your nuvi to a computer using a USB cable. The USB cable is included with some Nuvi packages. The computer must be on for the nuvi to charge.
Mar 11, 2011 | Garmin Nuvi 265W GPS Receiver
I have a Citizen C802DVD, that is dead, no power at all, what can be the problem? thanks for your help.
Instructions
    • 1. Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2 . Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • 3 . Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4 . Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Feb 02, 2011 | Vizio 42 in. LCD TV
We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Nov 17, 2009 | Televison & Video
Surround sound problems
you need an optical cable which it's sort of mentioned in the manual, but because of the multitude of possible ways to connect the TV to the sound surround, I did not figure out either.
I got my optical cable at BestBuy for about $45.00
Jan 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Jan 19, 2009 | Yamaha RX-V663 Receiver
Using the component 2 outlets
please read your owners manual for the samsung ptv to determine the best input to use and possible proper settings to adjust in your menu's.
Nov 15, 2007 | Samsung HCL4715W 47" Rear Projection...
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Sony Handycam DCR-HC36 wont playback on TV
if the sound is coming out on tv then the video cable has to be replaced. (You did not tell if the sound is coming out on tv)
Jun 25, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Durabrand DWT1304 13" TV Logo
71 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
