Question about Garmin StreetPilot 2620 GPS Receiver
Touch screen When I touch a letter or a number it reacts in another letter or number. If i hit 1 I would get 2---A and I would get B
  • 2 more comments
  • Anonymous Aug 19, 2008
    seems that the calabration for the screen is off. When you hit the one a 2 will appear. Hit the 2 and a 3 will appear. As you get toward the center of the screen, it works ok. The right side of the screen is off as well. I tried to get to the calibration screen with no luck. Can anyone please help !!!!!
  • CASSIPT Aug 21, 2008
    I have the same problem on my touch screen. I push A and get B and so forth. Extremely aggravating.
  • Anonymous Sep 15, 2008
    The left and the right side touch screen on my garmin 2620 does,t respond i tried the calibration that faild
  • skywagon185 May 11, 2010
    Crazymoose is correct about the screen calibration steps. However, my 2620 reverts back to its non-calibrated condition a day later, or when powered down and then up. I have not seen an answer to this problem
I havn't tried this yet but I will tomorrow.
Per the Manual,
To calibrate the touchscreen:
  1. Press the remote or unit MENU key.
  2. Select Display
  3. Press the remote or unit FIND key to begin calibration.
  4. Follow the on-screen instructions
Hope this helps!
Posted on Sep 14, 2008
Wow, thanks man, you rock, My 2620's screen became quite unresponsive and because you guided me right to the calibration method which was very easy btw fixed and now my garmin is working just fine. No need to upgrade. this is a great nav.
Posted on Aug 14, 2009
Ricoh aficio MP c3000 touch screen: displays, printer reacts to physicly pressed keys (number of copies changes on the screen etc), prints scans but does not react to touching the screen
the touch screen might be out of order, or if just when yo press something specific , as example the tray 1, an it react as you pressed something else then the touch screen need calibration. you can enter the calibration process by pressing in this right order the next buttons. first press once the yellow key then press 1993 and then press the red stop key 5 times and the lest 5th hold it for 10 seconds, after you release it press the blue number key pad 1 and then adjust the screen as it request the machine from you one order then other till the end for more info please write more info..
Oct 02, 2016 | Ricoh Office Equipment & Supplies
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
Touch screen not working
Well, if you touch screen is giving you trouble is because something happened to your phone, meaning it felt or hit it onto something. They don't go wrong because they feel like it. Something must to happen in order for it to react. If you want me to give a solution please let me know what happened to the phone.
Mar 29, 2014 | Samsung GALAXY S4
The touch screen isn't responding very well, sometimes it will react to a tap but mostly the screen is non responsive, the keys work ok when scrolling on a menu screen. any ideas?
first try to calibrate the touch screen.Take all games out turn on then go to the very small ds on the bottom touch screen. If you can't touch it move it with the cross down then hit a. Then select the option all the way to the right it looks like cross hairs that's the calibration screen fallow instructions. If that doesn't fix it it could be a broken screen or a loose ribbon.
Feb 24, 2010 | Nintendo DS Lite Console
Cannot connect ipod touch to the internet
Ok this is weird but i have had this problem.
In my case my password ends in a number so i hit send while still in the number screen. Apparently going back to the letter screen before hitting send caused the password to work.
Good Luck
Feb 03, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Calibration is not right on my garmin 330
If you think the touch screen is not responding properly, press and hold the Power button until the
Calibration screen appears. Follow the on-screen instructions.
Aug 15, 2009 | Garmin StreetPilot C330 GPS Receiver
The touch screen does not work. what can be done?
Are you using a screen protector? Because, in the manual, it warns that any screen protector used, will reduce the touch screen's sensitivity. But if the touch screen doesn't react at all, then it means that it's broken.
You might want to go to LG's website for support. :)
Jul 06, 2009 | LG KU990 Viewty
Brain Age/Nintendo DS not recognizing numbers or letters
hello there before you start up the game with the game out there is an option to calibrate the touch screen on the main ds menu it asks you to touch the screen in many places to calibrate it and this should sort your problem i had this problem playing sight traning and after i calibrated the screen it worked perfect my hand writing is poor to lol ( its Better To Type)
Cheers
Feb 04, 2009 | Nintendo DS Lite Console
Garmin StreetPilot 2620 GPS Receiver Logo
357 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
