Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
No power in the frig ..no lights, no sounds, nothing
Was cleaning the frig, water got into the bottom pan, after drying it out and replugging it in, there was no power anywhere..tried different outlets., no visible signs of a short...it's not even tripping the circuit breaker
    Scholar:
  • 150 Answers
Hmm. follow the power from the outlet to the point where you don't have it and fix the break in the circuit.
Posted on Aug 10, 2008
SOURCE:
My daewoo fridge freezer is leaking water from somewhere inside my fridga the model number is FR-4506S How can i fix this
Unless it has a water pipe plumbed into it then the water is melting ice or condensation, it's supposed to do this. You need to put a tray or some paper under it.
Jul 09, 2016 | Daewoo Refrigerators
Ice in bottom of freezer. What causes this?
Usually cause by a clogged drain in the back of the freezer. try to clean with hot water and make sure the water goes all the way downn to the drain pan. .
Note: all frost free refrigerator defrost a couple of time a-day; the water needs to drain into the drain-pan under the frig. check under the frig to see if the drain pan is totally dry, if dry, the drain is surely clogged.
good luck
Jul 22, 2014 | Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Water on the bottom of the frig under the crisper
some model's have a drain under criper's ck for drain and clean it . if no drain there its in the back just below the freezer .and can be seen from the back and if found clean it also . this water should be able to get to the pan under frig and not on the bottom of frig .. mm hope this helped .
Oct 21, 2010 | Kenmore Refrigerators
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Is your problem fixed yet?
Yes, I fixed my problem of the plugged drain that caused the ice to melt onto the floor. Apparently, frostfree frigs have a drain that leads to a pan under the frig by way of plastic tubing from inside the freezer compartment. The drain tube end for my frig only had about 1/8" clearance above the pan bottom. The pan was dirty with an ENORMOUS amount of dust that had collected. So, I had to move the frig out from the wall, remove the back cover at the bottom of the back of the frig. This exposed the white tubing and the gross pan of dust and water paste. I cleaned the pan, disconnected the tubing from the clip holding it in the pan and trimmed about 1/4" off the end to create a bigger clearance into the drain pan.
Make sure the frig is unplugged before you do the job so the evaporator fan doesn't hurt you.
Now, I will have to clean from behind the frig at least once a year.
Hope this helps. Good luck.
Bob
Dec 15, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
