Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Changing text message entry text from upper case to lower case
How can i do this?
  • erricsean Aug 04, 2008
    Thanks Mattik, I tried this already, unfortunately it did not work. The text mode remains on the upper case predictive text icon.
  • erricsean Aug 05, 2008
    thanks very much, the last solution did it!
    Problem Solver:
  • 10 Answers
To change from upper case to lower case.press and hold down the number sign button,and the different case would show up on the top of your text message.
Posted on Aug 04, 2008
  • Anonymous Aug 04, 2008
    hey here is another solution.if you look on the key pads,you would see on the 0 key there is an arrow pointing up.press that,it should change to upper case or lower,which ever you want.thank a lot,if you have any more problems feel free to shout back again.
SOURCE:
How do you add entries to phone book in upper and lower case?
At the time of adding the entries in the phone book, change the font to lower or upper.
Jun 05, 2010 | One Touch Jitterbug One-Touch Cellular...
I cannot text in lower case. How do I change from
When in text mode, press 1 (one) then press 0 (zero). That works on my Motorola Tracfone.
Jan 17, 2010 | Motorola Mobility TracFone® V170 Cellular...
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
I cannot figure out how to get my phone off all caps for texting
While on the message editor, press 0 to switch from lower to upper case and vice versa.
Oct 09, 2009 | Motorola Mobility TracFone C139-4 Cellular...
How do I use lower case letters in a text?
If your Tracfone has an uparrow on the zero (0) key, after entering a character, IMMEDIATELY hit the 0 key.  The phone will change the case of the previously entered character AND change case for subsequent entries.
If you're too slow typing the 0 key, you'll get the characters assigned (0, +, etc.) to that key.
Mar 11, 2009 | Motorola Mobility TracFone® V170 Cellular...
Text messages type in very strangely
When ready to type the message pulse #key for 2 or 3 seconds and turn Prediction OFF and problem solved. It works for my Nokia 3555.
Dec 19, 2008 | Cell Phones
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Hello
copy all text past in to microsoft word. select all text press function key F3 this wil change case upper and lower and tile case. u can switch which type u want
Mar 01, 2008 | Computers & Internet
One Time Entry
check your text button settings
I think it's the star button every time you hit it it will change the type of text from capital to lower case to numbers to symbles ect.
If it is not the star button look for the button with the arrow on it pointing upwards
Oct 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
405 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
