Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
TV chirps like a bird but does not come on.
I vaccumed the back then the TV went mostly blue picture, finally it stopped working and now only chirps like a bird.
  • 10,594 Answers
Please reinstall connectors on boards one-by-one. it is only dry joint issue.
Posted on Aug 12, 2008
  • Shahid Electronics
    Shahid Electronics Aug 12, 2008
    chirps like a bird means, tv trys to power up but shuts down of some error cuased by lose connection in any connector. just pull out and install again connectors on boards. hope problem will be solved.
    Shahid Electronics Aug 15, 2008
    any update about your TV? do you need further helpful info to fix it?
    Guru:
  • 1,894 Answers
Does this sound like some thing burning or sparking??
and do you see the stand by light blinking?
if yes how many times?
if you tell us the interval of blinks it would be much helpful for us to decode it.
Turned on the TV one day and there was no picture but sound. turned it off and then on again and had no sound and picture. Now when I turn it on some times I get an odd pixilated image. other times I...
Your timing control TCON board was going out and it finally went out, replace that and you will be back in business, they aren't a very expensive board most the time..under 20 bucks...Good luck
Nov 15, 2017 | Televison & Video
1999 ford expedition make noise when idle but stop when pickup speed. make a chirping sound when idle .i check pulleys & belt (ok) disconnect belt but still make chirping sound
Might be your water pump. Check for drips of antifreeze
Usually the bottom of the pump has a weep hole and the 1st sign besides the noise is antifreeze dripping from the weep hole
Jan 08, 2011 | 1999 Ford Expedition
Picture went out during thunderstorm. Won't show
The television may be repairable most tv shops ask a $20 fee to look at and tell youyes or know as to how to get rid of it if you dont want to bother with it all take it to your local dump and pay $10 for correct disposal.
Honetly to me it sound like thepower board was hit and can be repaired,
Jul 01, 2010 | Philips 60PP9202 60" Rear Projection...
No picture, sound is a loud chirp
NEED FLY BACK TRANSFORMER AND HOT TRANSISTOR
Feb 09, 2010 | Televison & Video
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
No av-input picture with sound
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
