Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Sears Trio model 795.75546400 error message: -88 * 88
I have a Trio model 795.46400 that just started displaying the following on the lcd display:
Filter Reset lit -- Freezer temp reads -88 -- Express Freeze symbol is lit -- Frig temp reads 88 and Lock is lit
Food in the frig is freezing and the lower sides of the unit feel warmer than they have in the past. The panel is locked and will not unlock. Water no longer dispenses which may possibly be from being frozen as well.
I called Sears who can't get here for 9 days! After reading hundreds of horror stories on various internet sites about recalls, motor fires, spoiled food, flooded floors, etc., I was hoping the customer service rep could at least look up the error code to make sure it's not something serious. I usually don't take out the extended service on things, but am sure glad I did non this frig. I love its features and convenience, but this will be probably the 4th time it's beig serviced. Additionally, I sent Sears tech support an email. Given Sears history of poor and slow service, I'm hoping someone out there might know what this means.
  • 2 more comments
  • clfischer565 Aug 04, 2008
    Mottozan: How do I reply to your follow-up question without getting charged again?
    Control panel shows the following from left to right:
    -Filter reset: Red light is lit (though not due for replacement yet)
    -Freezer temp reads: -88
    -Express Freeze: Swirl symbol is lit
    -Frig temp reads: 88 (though temp is now FREEZING everything
    -Lock: Red light is lit (press&hold does not unlock panel)
  • clfischer565 Aug 05, 2008
    Getting cool enough isn't the problem with the frig. It's that it is getting TOO COLD and freezing everything, and the panel is locked so unable to change settings.
    Thanks. I'll try a couple ideas and see if it works. Wish me luck!
    Master:
    Sergeant:
  • 462 Answers
Dear, u can try one thing it may work out but u may have to scarifice ur contents in the fridge.. switch off the fridge for about 5-6hrs.. it wud be best if its kept for one day... then look for water dispensers... clean them up.. and also check for any pungent or foul smell.. and then turn it on with all minimum settings..
Thankyou
Posted on Aug 05, 2008
    Brigadier General:
  • 6,966 Answers
An alternative supposition:
the 88 is not an error code; to my thinking, it is all the segments of the display 8 lighted up as 6 could be displayed with the top right segment dimmed or a 9 with the bottom left segment dimmed.
This is indicative of a logic/driver problem and therefore would be the main controller board which could likewise explain all other indicators are lit.
The fastest/easiest user action possible is to reset and unplug from the mains in the hope that it is just a system's glitch. Trying again after a few hours. Should this be not corrective, the only option left would be to wait for the authorized service personnel or perform a DIY (do-it-yourself).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Aug 05, 2008
    Allow me to repost the 88 display interpretation.....
    "the 8 8
    is not an error code; to my thinking, it is all the segments of the display 8 lighted up as 6 could be displayed with the top right segment dimmed in the same manner that a 9 with the bottom left segment dimmed."
  • Louie  Role
    Apologies to xx, did not notice your posting.
    hmmm, that fonts were not posted right, pls refer to the image below
    the reference would be "Man series 7 segment display"
  • Louie  Role
    that should be apologies to bbtoast
  • 319 Answers
As to the 88 display, there is one thing to try but it is a longshot:
Try to press the Energy Saver and Freezer temp buttons at the same time for 5 seconds, see what happens.
The 88 is not a used error code.
If that does not work then, I believe that Sears will be replacing your main board (motherboard)for this unit, as it sounds like it is bad.
Sorry for your trouble!
Brian
Posted on Aug 04, 2008
  • Brian Berndt
    Brian Berndt Aug 04, 2008
    By the way, you can reply to this posting, you will not be charged again.
    Brian
  • Brian Berndt
    If you have old wiring, frequent power supply issues (spikes, strikes, etc); these issues may be contributing to these issues!
    If you have other appliances that have frequent problems, you may want to invest in "whole house surge protection" or "Meter Surge Suppression".
    Or you just may have the unlucky refigerator!
    Good luck either way!
    Guru:
  • 1,894 Answers
A refrigerator or freezer that doesn't cool well enough may have a problem with its evaporator coils, condenser, or condenser fan motor. Frost build-up on evaporator coils, or condenser coils that are covered with dirt, dust, or lint can reduce how well a refrigerator can cool. If you notice ice getting thicker on the inside walls, inside bottom, or inside ceiling of the freezer, you have what is called a frost build-up. The problem is either with warm, moist air getting in through an old inefficient door gasket or the defrost system.
Self-defrosting refrigerators have coils and a cooling fan that need to be cleaned regularly. If the coils get coated with any contaminants, they may not cool the refrigerator properly. The coils are usually thin and black and they go through fins that dissipate heat, just like a car's radiator. They are located behind the lower kick-panel or on the back of the refrigerator. To clean them, turn the power off and use this condenser coil cleaning brush, or this condenser coil cleaning brush , and your vacuum cleaner. Even if your coils are below the refrigerator, you won't be able to get to all the condenser coils from the front, so it's a good idea to pull the refrigerator out and clean the coils from the front and the rear of the refrigerator. Give the fan a dusting as well. Sometimes other things can be the reason behind poor cooling, like the condenser fan motor. Anytime the freezer fan is running, the condenser fan should also be running.
A frost build-up inside the refrigerator usually means that there is a problem in the self-defrost system. You may even have damaged door gaskets. When you open the refrigerator door, you also let in a blast of warm, often humid air. This moisture usually freezes onto the evaporator coils immediately. Self-defrost refrigerators are supposed to self-defrost between two and four times out of every 24 hour time-frame. They basically turn off for a few minutes several times a day. A defrost heater kicks on to melt any frost build-up on these coils, which allows the frost and ice to melt, then it drains off to the pan underneath most refrigerators. Unfortunately, when a defrost component fails, too much frost builds up on the evaporator coils. When this happens, the circulating fan can't draw air over these coils. With no air flow over the evaporator coils, the refrigerator compartment will lose its cool.
To determine if the self defrost system is faulty, it's best to remove all the food from the refrigerator and freezer, turn your thermostat to the Off setting, and just leave the doors open for 24 to 48 hours, and let the refrigerator defrost. Keep an eye out for an overflow of water from the drip pan on the bottom of the refrigerator.
After everything has completely melted away, set the thermostat back to a regular setting. If your refrigerator starts operating properly, the symptoms lead to there being a problem with one of three other components in the self-defrosting system, the defrost heater, the defrost timer, or the defrost thermostat.
If, after testing these components, the refrigerator still doesn't get your foods cool, there may be a problem with the refrigerant level and you will need to contact a professional appliance repair person.
    Master:
  • 555 Answers
What is the error code that is displayed? It is not apparent in your post...
Kenmore Elite Trio Model 795 shows an error display Er IF
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Aug 29, 2012 | Cars & Trucks
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
It does not start and shows E9 error
Dear Sir:
I hope you are o.k
I will help you:
Please follow this step:
Error 09 - Lower PCA Memory Test Errors
Description
Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
found during the power up test sequence, error 09 will be displayed. This error code is only used
on products utilizing the dual microprocessor system.
Possible Causes
1. This error message almost always indicates a lower PCA problem when it is consistently
displayed. Failures causing this error message to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the lower PCA
should be replaced. It is possible to see this error message displayed intermittently due to
external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in this message being displayed. Treadmills operating on
non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Thank you in advance, sincerely. Blessing.
If you need additional Help , please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
Hi Ya! I was looking out for the solution of the Epson 1400 printer having black toner shows pop-up message; which displays "Consumables near end of service life". "Prepare the following...
If a consumable product reaches the end of its service life, the product stops printing and displays the following messages in the LCD panel or the window of EPSON Status Monitor 3. When this happens, the product cannot resume printing until you replace the depleted consumable products.
The photoconductor unit comes to the end of its service life. Even if this message is displayed in the LCD panel, you can continue to print for a short time by pressing the B&W Start or Color Start button on the control panel. The message in the LCD panel changes from Replace Photoconductor to Worn Photoconductor.
Mar 22, 2011 | Epson Stylus Photo 1400 Printer
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
Kenmore Elite Trio
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
    294 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
