Question about Magellan RoadMate 300 GPS Receiver
Will not turn on!
Worked a couple of days ago but now won't turn on with car adapter?
  • Anonymous Sep 23, 2008
    Magellan 300 gps will not turn on. Was running, but rather warm.
  • 1,800 Answers
Try another adapter exactly not the car adapter and see if it works
if its not upgarde it from the officila site
Posted on Aug 16, 2008
My compacq CQ 60 laptop won't turn on? When I turned it off a couple of days ago, I turned it off in hibernation. I had a couple of programs still open. Today, when I press the power button, nothing...
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Compaq Presario CQ60 AC Adapter 65Watt 18.5V 3.5A
Jan 28, 2013 | Computers & Internet
1995 Pontiac Grand AM SE. Heater fan works for weeks then won't go, try a couple hours later then it goes.
It sounds like the brushes on armature for (blower motor ) are worn. Sometime a bad spot on the armature from not being used often and also by being in the engine compartment where it is exposed to condensation. When the brushes stop at that particular spot, the blower will not start spin process unless it draws alot of current that may be why the fuse blew. You can remove the blower and examine or just make the change.
Jan 28, 2013 | 1995 Pontiac Grand Am
Can't turn on light
That can usually be economically repaired. Details are here.
Jan 09, 2013 | Maytag 2.0 Cu. Ft. Over-the-Range...
Dish washer won't turn on when start button is pressed
Check your door switch. My dish washer would not work a couple of months ago, tore apart and messed with door switch and it has worked every since.
Dec 22, 2011 | Washing Machines
I have a 1986 corolla that overheated frequently so i replaced the radiator and it solved the problem. it worked fine for a couple of days then the battery died completely. i replaced the battery a couple...
sounds as tho you may have a blown head gasket or cracked head caused by the overheating. Now you have water on top of the piston or in the oil and it is ceasing the motor.
Oct 14, 2009 | Toyota Corolla Cars & Trucks
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
Car wont start, contstant ticking from engine.
Locate the ticking noise. It is a relay that has gone bad.
Jan 12, 2009 | 2003 Renault 181
It won't turn on at all
http://sansae200.blogspot.com/
Mayb eit's corrupted. Have you tried recovery mode?
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
Magellan RoadMate 300 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
