Question about Cyberhome CH-DVD 300 DVD Player
My Cyberhome DVD player power on Button never turns to green
When i am trying to power on by remote or manual, it never turns green. But it displays in TV as if power on and no action is working like open, close etc..
  • 3 Answers
There was a problem with Electrolytic capacitors a few years back. It affected all kinds of electronics. When these capacitors blow, the unit may look dead or if operating act erratic.
With unit unplugged open it, and look at the power supply (small tan board). Check the electrolytic capacitors they are the taller cylinder shaped objects on the board. Look at the top of all of them, they should be flat. If any are bulged upward, they need to be replaced. The two suspect ones will be towards the front of the unit, by the transformer.
Posted on Aug 09, 2008
6ya staff
SOURCE:
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Sep 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
[email protected]
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Progressive scan mode
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Sep 17, 2008 | Cyberhome CH-DVD 300 DVD Player
Player was put on progressive scan and has stop displaying any video
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
CyberHome DVD player not responding...
The internal power supply has failed and is shutting down each time you try to turn it on. To remove your DVD there is a slot on the bottom labeled: Emergency.... with an arrow pointing the direction you need to push a lever to open the drawer. With good lighting you'll see the tab you need to slide over. Use a small flat blade screwdriver and the drawer will open enough to grasp it and pull it open. The power supply will need to be repaired, but it may have caused other damage and may be more expensive than buying a new player.
Mar 06, 2008 | Cyberhome CH-DVD 300 DVD Player
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 300 DVD Player: pal to ntsc mode?
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Froze at "Reading"
If you are lucky to have a normality relapse, maybe after resting the DVD recorder for a while, you could try 2 firmware updates found here - http://support.cyberhome.com/support_web.nsf/All_Docs/?SearchView&Query=(DVR%201500)%20AND%20(Downloads%20and%20Updates)&Start=1&Count=10 But theres a 99% chance that you're stuck in the initial setup mode(have you just puirchased it?) - if you wish to skip this setup press- > enter > return > enter - on the remote panel, make sure to press every button only once. If you wish to go through with setting up the date/time etc, then follown the instructions in this addendum to the manual: ftp://209.237.61.78/cyberhome/1500/manual/1500_add.pdf Good luck
Mar 27, 2006 | Cyberhome CH-DVR1500 DVD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
44 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
