Question about Nakamichi SoundSpace 8 System
Fan noise the subwoofer fan makes too much noise.
  • 101 Answers
Common problem, the fan needs remounting on the chassis, open up and attatch
Posted on Aug 04, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Why does Infinity TSS-1200 subwoofer make grinding noise?
If it isn't brand new, it sounds like the voice coil is striking. This can be caused by damage to the suspension system or simply an overheated voice coil inside the sub. No easy fix unless your handy at rebuilding speakers. I would suggest buying a new one or sending back under warranty if it is still within warranty period
Aug 11, 2014 | Audio Players & Recorders
Loud buzzing noise
Is the vibration coming from the heatsink itself or from the fan running at high speed?
I highly doubt the processor itself is vibrating; no moving parts to vibate. A more likely suspect would be one or more of the fan blades having gone out of balance and causing it to resonate at certain RPMs.
What cooler are you using?
Increase Engine Horsepower.
Jun 02, 2012 | KLH ASW10-120 Subwoofer
Engine makes alot of noise
There can be many reasons for the noise but if you can pour some water on the fan belt and the AC belt while the engine is started and if the noise drops off then the belt can be faulty. Also check the pulley idler, check the water pump. If not there can be faulty timing chain , idler or within the engine.
Feb 18, 2011 | Car Audio & Video
My sw 15 sub woofer is making aloud humming noise ithink it is oprably the fan
Most likely, you could feel the fan if it was that, but it could also be the the cord that connects the Sub to the main console, much like guitar feedback on an amp
Aug 18, 2009 | AudioSource SW-15 Subwoofer
Amp makes noise when volume is off
Subwoofers are more susceptible to magnetic and radio frequency interference than your average speaker, or more commonly called RFI.
If you have a RadioShack or other electronics store nearby, purchase a ground loop isolator. This will ground any of the stray electrical pulses around your subwoofer. It is very easy to install and plugs directly into the RCA jack of the subwoofer and should eliminate the problem.
If this does not solve your problem, I suggest bringing your unit in for service if the noise is bothersome.
Aug 18, 2009 | JBL ES150P Subwoofer Speaker
What cause subwoofer to make constant noise(loud)
usely it turn out to be a ground issue make shure there are grounded with the PROPER guage of wire or heaver the required
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Subwoofer stopped working
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
Nakamichi SoundSpace 8 System Logo
211 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
