Question about Microwave Ovens
Whirlpool g2 microwave model #gh6177xpb-3 the lcd touch sceen is inop. With X high failure and X low failure. I can not seem to find a wiring schematic for the touch screen matrix or the electronic control to determine which is bad or if you know of any problems in this area Thanks John
  • ok_lovings May 18, 2009
    We have the same Micro-hood and everything works on it except the touch screen. We have the same Failure notices on the x High and X Low this is exactly how it reads
    X Hi Fail 255 57
    X HI Lo Pass 255 0
    X Lo Fail 243 0
5 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: powere went out and i
sounds like the main control panel..
Posted on Jun 20, 2008
SOURCE: kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Posted on Aug 16, 2008
dnewcombe1
  • 1564 Answers
SOURCE: G2 touch screen doesn't work any longer
You must remove the vinyl cover from the control panel and wipe down the face underneath it with denatured alcohol. It's pretty tricky depending on your mechanical caliber.
Then clean the inner side of the vinyl cover the same way. Caution don't soak the power unit just dampen a cloth, this goes for the cover also!
Posted on Aug 13, 2009
  • 9 Answers
SOURCE: my KHHS179LSS-3 will not let you control microwave
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
Posted on Sep 26, 2011
Whirlpool gh6177xpb microwave error 252 on touchscreen at startup. How do I fix
clean ribbon cable that goes from pad to control board with denatured alcohol undo lock unplug cable clean contacts
Nov 23, 2014 | Whirlpool Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KHHS179LSS-3 touch screen has stopped working. When I un-plug it and then plug it back in, I get a "Touch Error" message saying 'Y High Fail 255 95; Y HiLo Pass 255 0; Y Low Fail 255 0; X...
There is no reset other than unplugging the power for a minute then plugging it back in.
If this in under warranty I would contact the manufacturer via the information in your owner's manual for a free repair.
If for some reason you don't still have yours, you can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
If it's out of warranty, we repair these controllers for $39.95, or you can order an LCD assembly (part number ) from the Pros here or get a refurbished unit from us here.
Oct 09, 2011 | KitchenAid KHHS179L Convection/Microwave...
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Aug 13, 2009 | Microwave Ovens
My g2 microven touch pad will not work, everything else works. I unplugged it and plugged back in ,shows touch error high fail 255 177 and low fail 246 0
Hello there
looks like you have a touch pad that has shorted out and is in need of replacement
please go to www.whirlpool.com and they have a technical help section ok.
best regards mike
Jul 31, 2009 | Whirlpool Microwave Ovens
Whirlpool microwave g2- touch screen. The touch screen does not work properly. If you touch a command a differnt command/menu comes up. Some menus are inaccessable.
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 10, 2008 | Microwave Ovens
Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Jul 16, 2008 | Whirlpool MH6150XM Microwave Oven
Microwave Ovens Logo
217 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
