Question about Canon PIXMA iP2000 InkJet Printer
Faint Printing I have changed my inkcartridge and cannot get the print to print clearly with the new cartridge. It prints paintly.
  • Anonymous Mar 15, 2014
    did not change settings ...1st print is good....subsequent prints are very faint
    Sergeant:
  • 152 Answers
It could be a old ink cartridge was installed even if you just bought it check the date.The jets maybe clog from the previous ink cartridge if it was not used often.If the date is good I would go into the utility settings on the printer and do a print head cleaning.
Posted on Aug 04, 2008
SOURCE:
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
Faint printing on samsung ml7140 laser printer -- even when cartridge is new
try adjust the toner aditiute by going in to the printer properties. adjust to 3 if posible and do a test print. If the print out is still faint. try update the firmware of your printer by going to www.samsung.com
May 15, 2010 | Samsung ML1740 Laser Printer
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Not printing
try the cleaning cycle again and see if it gets and darker.
also try a test print as these utilise all colours and may help clear out any blockages.
Feb 27, 2009 | HP OfficeJet d145 InkJet Printer
OfficeJet G85 Makes Unreadable Copies
Usually, it's the print cartridge. I recently installed a new black cartridge on a 6110 printer and it, too, was very faint in printing. It turned out to be "dried up", even though it was a new cartridge in a sealed bag (but purchased in 2005).
Feb 07, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
My printer or printers all have the same problem
The printing area inside is defected.If you repair,you have to change the printing side fully.Better get a new one.
Feb 01, 2009 | Samsung CLP 315 Laser Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Printing problem with Canon iP2600
Appears to be a defective color cartridge. Verify the printing is not set to fast or draft.
Dec 15, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Pixma mx310: error message check ink u163 will not delete after replacing colour inkn cartridge cl 41. unable to use printer.
Ink has run out. Replace the ink cartridge and close the Scanning Unit (Printer Cover). If printing is in progress and you want to continue printing,press the Stop/Reset button for at least 5 seconds with the inkcartridge installed. Then printing can continue under the ink outcondition. The function for detecting the remaining ink level will be disabled. Replace the empty ink cartridge immediately after the printing.The resulting print quality is not satisfactory, if printing iscontinued under the ink out condition.
Thanks for using Fixya
source : http://support-au.canon.com.au/contents/AU/EN/8200172900.html#6
SAM ANDERSON
Sep 26, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP2000 InkJet Printer Logo
91 people viewed this question
Clive
Clive
old marine
old marine
Ekse
