Question about GE WCVH6260F Front Load Washer
Softner won't drain
Softner doesn't drain during cycle, everything else seems ok
  • 101 Answers
Sir,
if you mean that the softner (from the detergant drawer) will not enter the drum during the normal cycle, then....
the softner has become solid, you need get hot water and get the hardened softner loose within the pipe to the drum clear.
I suggest using a solid electrical cable core to clear it
Posted on Aug 04, 2008
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
My question is this..why doesnt my clothes smell like fabric softner?? They dont smell at all..like i never put anything in there...and the fabric softner compartment never fully drains of its water what...
The fabric softener may be unscented.
The softener compartment is flushed during the wash cycle to clear it completely, therefore some water remains at the end.
Aug 01, 2014 | Washing Machines
Cabrio wtw7600xw2 when water enters the bleach or softner dispensers it runs over and leaks on floor. I've cleaned the outlets their clear. Seems too much water comes in to dispenser areas.
If the lines to the drum are clear and draining properly then you will need to replace the water inlet valve since it is allowing to much water to pass through to the dispenser. Here is that part to order. Whirlpool W10326913 Valve AppliancePartsPros com
Mar 03, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
I have an kenmore elite top loader washer model 110 27087602. During the spin it makes loud clunking noise. I seen the other post about the agittor nut sometimes loose but I do not see this nut under the...
The most probable thing that is making that noise is a broken motor coupler if it drains but the tub doesn't move or even if the agitator doesn't move (espically the lower section) on the wash cycle the coupler is the problem. I have included a youtube video that will show you step by step how to replace the coupler http://youtu.be/9K1KHEogf3c
If it does agitate let me know and ill tell you how to completly remove the agitator to check that drive block you refer to as nut under softner dispenser
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Washing Machines
Softner stopped draining out of the compartment during the rinse cycle. When I open the compartment after cycle stops, there is still softner in the cmopartment
try pouring really warm water in the compartment or using small soft toothbrush type brush to clean out the build up of softener. You might try thinning your softener in the future with water if it is very thick. this works for me
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric softner still in compartment after wash is completed
take out soap box first and clean,i would say that water valve coil is probably blown though,should read around 3kilohm resitance checked when unplugged hope this helps
May 06, 2009 | General Electric WBVH5100HWW Front Load...
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
GE WCVH6260F Front Load Washer Logo
108 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
