Question about Fossil Watches
Changed the battery in my fossil watch series AM-3692. The watch will not work now. Battery is the same number and manufacturer that was in the watch originally.
  • 109 Answers
You may have thought your battery was bad, when in reality the watch had a problem to began with. You also may have bought a dud battery. Have the battery tested, if good you either have a mechanical problem ( there is something stopping the gears from moving) or you have a electrical problem ( the curcit board or coil is shot). Fossil has a 11 year warranty on most of their watches, and even if you don't have your original reciept, I would get ahold of them and ask what they can do for you. Or you can take it to a watch repairman to repair but it will cost you.
Posted on Aug 04, 2008
What is the battery number for a fossil am3848
We can tell you the battery number you may need for your Fossil Watch, but it is not worth you to change it yourself.
Many people think that replacing a battery to a watch is an easy task, but that is far from truth.
Note that once a watch is opened ( if you can get it without leaving marks all around the case) all circuits are extremely delicate. If you may touch some part with any metal instrument or even with your fingers, you will loose your watch.
Best you can do is take it to be replaced to a watch shop, sure you have one near you.
But let me insist, if you need the battery number, let us know and we will provide.
TicTacArea.com is Fossil authorized dealer, you can find our complete Fossil watches and Straps for Fossil watches here:
Apr 04, 2014 | Fossil AM3848 Watch for Men
I've changed the battery in it, how to set the correct time and date?
Different watches have different methods, go to a web site manufacturer and look up your model and look for the instructions. For example look at:
http://www.fossil.com/wcsstore/Fossil/images/en_US/customercare/analog_Automatic_WeekdayDate_2502.pdf
Dec 06, 2010 | Watches
I have a big tic watch but after a battery change the digital number display on watch face no longer works,why?
Who changed the battery, you or a watch repair serviceman? Did you replace the battery bar after you replaced battery? Did you check and see if there was a second battery (some watches have two)
You may need to have it serviced. Or try Fossil at :
http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
Aug 23, 2010 | Watches
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
Jun 14, 2010 | Fossil JR8096 Wrist Watch
Fossil watch dead
1)Get the battery out again and check for power. 1,5 Volt batteries should be 1,52V - 1,54V and the 3Volt batteries shold be 3,1V - 3,3V in charge.
2)Take the hardened steel needle or watchmakers screwdriver and clean (scrape) both contacts off any visible residue till they are shiny. aaaaaaaUce dust blower to get rid of scrape-offs.
3)Make sure the contacts are touching the corresponding battery side only and not shortcuting the battery.
Do not forget to rate please.
Mar 07, 2009 | Fossil Arkitekt watch
Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Jan 26, 2009 | Fossil AM 3688 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
340 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
