Question about Microsoft Windows Vista Ultimate Edition
I need a recovery disk for a emachine model W3105
  • 65 Answers
The following is a link to your computers support page.
I would suggest to contact their company and request them to send you a copy if it is still under warrenty. I this however fails i would then suggest to purchase a entirely new O/S. however this is costly. This is because the recovery disks are burned from your computer's machine ID. another words, the hard drive, set a certain machine code and those recovery disks are code sensitive. I personally have never been able to recreate a recovery from another source, even with Identical stats.
Posted on Aug 04, 2008
So well meaning person disconnected the three wires going to HD LED, Power I do not know what they were connected too originally.
Look along the edge of the motherboard for markings next to a set of pins. You may see markings to indicate what pins go where. Use the old board to help examine where the pins may be located. HD will go to your HD LED - Polarity will be important here, so when you get it wired, if it does not light you will need to reverse the wires on the pins. Power will go next to a Power indication, and the last probably will be a RESET. Once you get them hooked up properly, they should work for you.
You may be able to download the manual from here:
Mar 21, 2015 | eMachines W3105 Motherboard Replacement...
Need recovery disk
go to internet and put your models and.............
Aug 07, 2012 | eMachines ET1331G07w (884483025329) PC...
How do i make my computer just like it came out of the factory?
1. Recovery Disk - usually bundled CD with a new laptop or deskop PC 2. If the disk is not available, try checking on the manufacturers site if the recovery disk is available for download ( EMachine Homepage) 3. Some Desktop already have the recovery data saved on a slave drive. Try to verify the model of your Desktop and search it on their homepage
note: disk recovery will delete files, so be sure to backup important data before performing a recovery
Nov 09, 2010 | E-Machines eMachines Desktop PC
After reinstallion, no emachines recovery/original programs/apps
Your recovery software is usually comprised of more than one disk. You should have one windows disk in addition to the eMachines disk(s). Complete recovery requires that you use all the disks, in order to return to original state. If you are missing programs, it is because you did not use all the disks.
Option A: Go here to order a complete set of recovery disks:
You will need your machine serial number to ensure you obtain the correct recovery disks; they are about 20$ plus shipping.
Option B: Use your eRecovery: Restart the computer and when it begins booting up, you have to hit repeatedly/hold down a key to enter the Recovery management menu. As for the key, it varies from manufacturer to manufacturer, but try the F10 key for starters. If it's not that one, try the F12, or the F8 key. That should get you pointed in the right direction. Just follow the screen prompts, and choose RECOVERY, not RESTORE. Also make sure you choose Recovery without disks.
Reply if you need more help.
Hope this helps.
Mar 08, 2010 | Computers & Internet
Trying restore emachine need full back up discs model 590/790
You can order a set of recovery disks here:
They are about $20 plus shipping, and you need to input your machine's serial number to insure you obtain the correct disks.
Hope this helps.
Mar 07, 2010 | E-Machines eMachines Desktop PC
How do I create a factory default recovery disc where do I find the area at
Not knowing the age and model of your emachine I will give you a few choices.
If it's an older series like the picture above you should be able to go into the start menu, all programs and then either PC Help and Tools or Emachine-Recovery manager. Then select Recovery Disk Creator.
If it's a newer model, Emachines and Gateway were bought out by Acer over a year ago and now use the Acer style recovery. Select Star, All Programs, then Emachine Recovery Manager. Load the Disk Creator selecting Factory Default disks first then selecting Application and Driver Disk.
One note, if it's an older model you will only be able to create the application and driver disk. It would have came factory with a base windows install disk. If you have lost this disk, you can reinstall using any standard OEM disk for the correct version of windows and using the windows license attached to the computer, but you will need the application and drivers disk to install your devices and programs.
If it's and older model and you can't find the disk, you can order a replacement set by contacting Emachines support, but there will be a cost invloved.
Feb 12, 2010 | E-Machines eMachines Desktop PC
How to put the recovery partition back on the emachines t5048
As far as i know the only way is to run the restore disk from emachine that is for your model computer. (it usually wipes the computers hard disk in the process.)
the link below will take you to their support site for drivers.
on that site look for eMachines Recovery Media Purchase Program and you can see about ordering the recovery disk that you need.
Sep 15, 2009 | E-Machines T5048 (7136) PC Desktop
I need a recovery disk for a eMachines W3619 computer
Emachines will sell you one for about $25 USD.
Jun 24, 2009 | Computers & Internet
Restore emachine
Your machine has two ways of repair: SYSTEM RESTORE and SYSTEM RECOVERY. System restore is a Windows utility that rolls the machine back to a point where the machine worked before the problem. System recovery is an eMachines tool that puts the machine back the way it was when you first got it. Restore wont delete your data, recovery will and can. If the problem is catastrophic, and youve backed up your data off of the machine, use the recovery option. Your recovery partition (or a recovery disk) is needed to do this, and it involves pressing a key while the computer boots up. Check your documentation for your model of machine.
Mar 24, 2009 | E-Machines (T2824) PC Desktop
Microsoft Windows Vista Ultimate Edition Logo
100 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
