Hi it may work in the device if first you use a PC and format the SD card FAT16, (Or whatever format your device may use) Then return it to the device, often it will then be "seen" and one is then able to Format it with the device, then it should work fine.
If it cannot be formatted in the PC then it is faulty, as it would be too, if after a format it was put back into the device and it wasn't "seen".
