Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Belkin PRE-N 632614
I cannot locate this IP address to go in and add a MAC address. It used to be 198.168.1.1, etc. but now it is not working!
Any help is appreciated.
    Sergeant:
  • 152 Answers
It should be 192.168.1.1 if that does not work you will have to try a hardware reset...
Posted on Aug 04, 2008
SOURCE:
How do I enter a mac address?
hi Buss.
Open a web browser and enter <IP address of your wireless route> (the default IP for most Belkin routers is 192.168.2.1) and press Enter. Click Login button to open the login screen. When the login window appears, enter a password. Select Wireless ->MAC Address Control from the menu on the left.24 Oct 2010
How to add MAC address to wireless router - WintelGuy.com
wintelguy.com/2010/20101024_mac_filter.html
plus try this link.
How do enter mac address Google Search
Dec 02, 2017 | MAC Computers & Internet
Smartbro canopy ip address
IP address of your router can be obtained from Ip-details.com .I use this site to get my IP address. It provides additional information about an IP like Internet service provider, location of an IP address,latitude,longitude etc
Jan 11, 2013 | Belkin Computers & Internet
Cant find the install file for the belkin software for mac
There is no need for installation. Just locate the ip address for the router's settings page and make all the apropriate settings. In case you don't know the ip address it's the same with the gateway's ip that can be found at the connection's properties.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 06, 2010 | Belkin F5D7234-4 Router
My belkin wireless does not work, if I hook up straighth to the belkin it works, tried resetting
1. You may want to do the firmware updates.
2. Check the wireless channel
3. Check MAC address control . You will have to "allow" the wireless device here.
4.Check the the firewall settings in the router.
this is all done in the routers configuration page usually at 192.16..0.1. This ip address is type into the browser URL or Address locator.
May 05, 2010 | Belkin Computers & Internet
Mac OSX 10.5 doesn't seem to work with Belkin model F5D7230-4
I get the feeling it is a security problem on your wireless access point. Try turning security off temporarily and see if the problem goes away.
The fact that you can connect to other networks tells me that your mac book network config is ok.
The reason the manual ip configuration doesn't work is because wireless connection connection has not succeeded. Kind of like not having the cable connected and expecting to find your DHCP server.
One thing that comes to mind and drove me completely insane once is your wireless network name (ssid) is case sensitive. So homenet is different from Homenet for example and you won't get any decent error messages.
With the security make it as simple as you can then slowly turn stuff back on (WEP and MAC filters for example) until it breakes again. Then you will know where your problem is.
Hope this helps.
Aug 16, 2009 | Belkin (F5D5231-4) Router
Adding ipod touch to wgr614 network
In MAC Address binding, you should put the actual MAC Address of the iPod not the IP Address, they are different. Normally the MAC Address of the device can be seen on the sticker at the back of the device. Another way to identify the MAC address is go to Menu/Settings of the device and look for Device/System Information. MAC Adress usually have 12 hexadecimal characters (6 pairs). Now locate the MAC address of your device and enter that in the MAC Address Binding settings. That should work.
Jul 09, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Need to add a computer to the DHCP client list of Belkin router
You can't add a computer to DHCP Client table manually, because DHCP client table is automatic. If you wanna know the MAC address of your computer, go to Start > Run > type CMD and press enter. On the command prompt type in IPCONFIG/ALL and look for Physical Address. That is also the MAC Address of your computer.
Jun 28, 2009 | Belkin (F5D9230-4) Wireless Router...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 07, 2008 | Belkin (F5D5231-4) Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
47 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
