Question about Lexmark X5470 All-In-One InkJet Printer
Where is the place to change ink cartridge
Hi I can not find the place where the ink cartridge is. Could you pls show me. Thanks a lot. I so appreciate that
  • 2,035 Answers
Please sue this link:
Good luck..
Posted on Aug 07, 2008
Light flashes cartridge change, and change the cartridge and still flashing hp deskjet 920c
Make sure Orange protective cap (tape) has been removed from the bottom of the ink cartridge.
Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press PUSH mark until ink cartridge click into the place.
Hope this will solve your problem.
Thanks for using Fixya.
Oct 21, 2010 | HP DeskJet 920c InkJet Printer
I have an epson RX560 that wont recognize an ink cartridge. I have already successfully used the multiuse chip on previous cartridge, but when I changed cartridge it showed fault message. I have tried...
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
I located a page on forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 26, 2010 | Epson Printer
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Keep ink cartridges out of the reach of children and do not drink the ink.
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
I had a problem with my printer canon pixma mp145
Hi you said that the black cartridge is good but when you insert them, both cartridge cannot be recognized, now your problem is the tri color cartridge, yes it really happens even if the other cartridge is good and the other is defective. I guess your from the philippines so try to buy re manufactured tri color because it is cheaper than the genuine. God Bless!!
Sep 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HPofficejetpro L7580 doesnt recognize cartridges have been replac
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
Epson Stylus CX 6000
There is an option on the control panel to change an ink cartridge after pressing menu button, go to maintenance and go to change ink cartridge. if you are having difficulties still, get back to me. thanks for using fixya. pls rate solution if it helps. keep me posted.
Aug 17, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
