Question about Sony Televison & Video
Hello have a sony KDF 50E 2010 LCD PROJECTION TV. When I plug in my ps3 via hdmi get a ghosting picture also if i plug in my wii via scart ghosting on screen also happens. is this normal and can i rectify it in some way many thanks
  • 1 more comment
  • maarte Aug 04, 2008
    the ghosting stays on all the time while playing a game on either console it looks like a blue ghots picture with the normal colour pic
  • spec-ops Aug 21, 2008
    Hey, my TV's much the same (50" KDF-E50A12U) and I get the ghosting with MY PS3 too! I'm not going back to scart now I have a HDMI so how can I fix this?
    thanx,
  • paul thomson May 11, 2010
    HAS THE GHOSTING PICTURE LASTS FOR LONG TIME OR JUST FOR FEW SECONDS AFTER SWITCHING ON?
Hi. i had the same problem with the hdmi lead. luckily it was still under guarentee, when the bloke came out to mend it. it was the settings that was wrong he changed some numbers on the remote and it works fine now. with the sound of it most of these tvs are set wrong for hdmi ..
Posted on Dec 30, 2010
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
A yellow line has appeared at the top of my Sony Bravia KDF 50E 2010 rear projection tv screen, anyone know what this is and possible fix.
Its a good chance that the Optical Assy Block needs to be replaced,also known as the Light Engine Sony is real Famous for having Bad Light Engines. PN# A-1197-241-A
Here is some companys who have rebuilt Light Engines
Encompasss Parts Distribution 1-800-638-3328
UED 1-800-648-6657
PTS 1-800-844-7871
Jan 14, 2011 | Sony KDF-50E2000 50" HDTV
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
I have had my ps3 connected to my hdmi lcd but now when i connect via the scart plug on an older tv no picture appears how do i sort this
This is because your PS3's Display Output it set to HDMI, therefore the SCART isn't active. I believe the PS3 has a video reset. This should be how it's done:
1. Shutdown your PS3 if you haven't done this yet.
2. Press and hold the powerbutton. It should beep once for power on and shortly afterwards beep again.
You'll have picture on the other cables and the resolution is reset to 480p. You can change the settings now.
You'll probably have to do this again when you plug it in to your LCD with HDMI again.
I hope this helps, please don't forget to rate.
Greetings,
DarkNeogen.
May 22, 2008 | Video Game Consoles & Games
Sony 40V3000 - Ghosting whilst viewing via SCART (Freeview is visable through picture)
have you tried plugging your sky box into another scart socket on your tv set
Mar 11, 2008 | Sony BRAVIA KDL-40V3000 Television
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony bravia 50 inch projector tv kdf-50e2010
how do you remove the screen from sony kdf 50e 2010 i have removed screws from top and sides of tv but cant see how to release bottom of screen
Nov 07, 2007 | Televison & Video
Televison & Video Logo
142 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
