How do I prevent mold and odor from my kenmore elite front load washer.
  • 5,911 Answers
Please click on the following link for an explanation on how to get rid of odor and mold problems in a front loader:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally have own one of these washers for over 8 years now, and have not had any problems since I started following this advice. I hope this helps you.
Posted on Aug 04, 2008
Heavy mold build up around rubber boot inside and out. clothes smell moldy when taken from finished cycle kenmore elite he4t model...
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
You can use use a 50/50 mix of bleach and water to clean the door bellow thoroughly with a scrubbing pad to get rid of mold and mildew. Use the green kitchen type scrub pads as they are not as abrasive. Do not use steel wool. If the mold becomes permiated in the rubber and will not come off, you will need to replace the bellow to get rid of it. The following link explains how: http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load Replacement parts (if required) can be purchased from any of the following websites: searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
FOUL, MUSTY, MOLDY ODOR THAT GETS INTO CLOTHES. CLOTHES SMELL BAD
If this is a Kenmore Elite front loader, such as the one you posted this question under, the odors generally come from mold, mildew, and/or debris in the drainage system. The following link explains some preventive measures you can try that will minmize odor problems and prevent the develpment of harmful mold and mildew:
If you have a serious mold or mildew problem on the door bellow and cleaning doesn't help, you may need to replace the seal to get rid of the problem. The following link explains how:
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite oasis washing mchn has a bad odor and cloths smell
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Mold on the gasket of kenmore duet front loader. have run the clean cycle, and scrubbed the gasket and inner liner also
This is a common problem with front loading washers. To prevent this issue leave the washer door slightly ajar after use. It will promote air circulation and prevent mold.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Elite washer has a musty odor. I have run an
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Odor from the inside of our front load laundry washer
leave the door ajar between uses if possible , there is a product on the market now to assist the odors of front loaders. www.affersh.com . you MUST also use an HE detergent ( specifically designed for front loading washers)
Nov 13, 2008 | Kenmore Washing Machines
HELP!! Kenmore Elite top load STINKS during use
Apr 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
