Question about Sharp AR-160 Copier
Sharp AR-C150 parts
I have a sharp ar-c150 and the paper is coming out wrinkled and I think it has something to do with the fusing unit because the ink is not permanent sometimes. I want to know if if it is worth changing and where can I find parts for this copier. I have been having trouble finding parts.
Thank you, Rdodney
  • Sharp Master
  • 2,794 Answers
See if this site helps
I use a company called precision roller as well.
Posted on Aug 06, 2008
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Does anyone know how to clear a erro code L4-06 from a Sharp AR-C150 copier?
L4-06 isn't something you can just 'Clear down', there is a problem with the Primary Transfer Belt.
Get a suitably Qualified Engineer to check the machine or be prepared to pay for a complete set of Drum units if you just clear down this error code and continue to run the machine.
Hope helps.
Jan 24, 2011 | Office Equipment & Supplies
SHARP AR C150 COPIER-ERROR MESSAGE H4-01
H means heat, you have a bad fuser.
Jan 28, 2010 | Sharp AR-C150 Copier
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
I'm looking for a service manual for a Sharp AR-C160 Color Copier & Setup instructions for the sorter/stapler. Yes, I've found them online several places for a price, but why should we pay for them?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
AR-S160(Japan only )
AR-160(Except Japan )
MODEL AR-161(Except Japan )
Exteriors
Operation panel section
Side door unit
Optical unit
2nd,3rd mirror unit
Middle frame unit
Process unit
DV cartridge unit
Fusing unit
Main drive unit
Base plate unit 1
Base plate unit 2
Manual paper feeding multi unit
Delivery frame unit
TC case unit
250 sheets tray unit
Packing material & Accessories
MCU PWB
I have this one, but i can't send a file writ to me to goodgold@inbox.ru
May 13, 2009 | Sharp AR-C160 Color Copier
Needs simulations steps on how to reset a E8-000 code
Hello sir; This error code have no way to reset, the ptoblem is icu or pcu main board .
Apr 27, 2009 | Sharp AR-C150 Copier
I just buy it and whene i plug it ,it gives code ou-80,h2-00
Your error code indicates that the Fuser is not at the correct temperature, which can lead to smeary smudgy copies or scorched paper and a fire hazard, depending upon whether the fuser is too cold or too hot.
Replace the Fuser Unit.
Apr 26, 2009 | Sharp AR-C150 Copier
AR-206 copying problem / paper comes out slanted
There could be somthing in you ADF that is keeping the copy from going in properly. Your tires could need cleaning or there could be something going on with a component in the ADF.
Sould have a technician inspect the ADF to see if it needs cleaning or parts.
May 30, 2008 | Sharp AR-207 Copier
Sharp AR-160 Copier Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
