Question about HP Compaq Presario V5000Z Notebook
V5000 won't boot but makes a crackling noise
My Presario V5000 made a crackling noise near the power cord insert when I tried to boot up this morning. Also the fan runs. I changed out the power cord - that's not it - and the fan stayed running till I took the battery out (and runs again when I put the battery back in). I had it on a trip and everything worked fine- didn't drop it, etc. - and I inpected some of the interior and could see no damage of any kind. help?
  • 52 Answers
Try flashing the bios
Posted on Aug 08, 2008
Compaq presario v5000
Your laptop runs on 18.5 volts DC at 3.5 amps.....Check the output on the printer power pack, if it is not the same, you have probably cooked your motherboard and that is what you will need to replace. Laptops do not under any circumstances like power that is not speced to thier configuration.
Sep 29, 2009 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
Dell Inspiron 8500 doesnt continue boot up
is the crackling noise constant?
if so, your hard drive is lockup on the bootup. you have to get a new hard drive.
or you can try to reformat the hard drive, but I don't think that will help.
Jan 03, 2009 | Dell Inspiron 8500 Notebook
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Blank screen problem witn presario v5000
This will not kill your computer don't worry.
What would be mt suggestion for you, please get your presario v5000 reimage with all the drivers.
Thanks
Aug 25, 2008 | HP Compaq Presario V5000Z Notebook
S-Video port on my Compac Presario V5000 Laptop
try installing manufacturers Drivers for your video card... You're probably using the "default" drivers.. Might fix it to get the current ..
May 17, 2008 | Compaq Presario-Notebook 900 Series Video...
Compac Presario V5000 S-Video problem
Perhaps you can change your resolution or your refresh rate on the out to TV? Give it a try.
May 17, 2008 | HP Compaq nc6230 Notebook
First sheck and configure display properties > settings > advance for multiple or external S-Video TV. Check device manager > display adapter > update drivers. Restart.
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000Z Notebook Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
