Question about Dell Dimension 5100 (D51L1) PC Desktop
XP won't recognize 2nd SATA drive and shows 1st SATA drive as drive F:
The Background:
A direct hit lighting strike took out my UPS, power supply, DVD, backup drives, sound and motherboard. Dell tech support sent a guy out and he replaced everything. When we powered up to the Windows log on screen the system froze. It did this repeatedly. Tried to go to System Setup and tried booting into Safe Mode but each time the system jumped to the logon screen and froze up. I have to find a way to recover the files.
Steps taken so far:
1. Replaced everything but the harddrive.
2. Purchased new SATA 80GB harddrive, same as the older one.
3. Installed new SATA and loaded windows XP.
4. Spent five days chasing down drivers for all the items with question marks on them in Device Manager
5. Still have a question mark on PCI device but can't figure out what that is as only the NIC card and Video card aren't on the motherboard.
6. In setup, I can see my old drive, it shows up and in the boot sequence.
7. I can get to windows on the new drive and two issues come up:
a. Windows shows my new drive as drive F: and even unplugging the older drive and rebooting doesn't change the drive letter to C:. I tried going to Computer Management, then Device Management, to change the drive letter and that didn't work either.
b. Windows does not recognize the second drive.
Summary:
Can't access the older SATA drive
Can't see the older SATA drive in Windows XP
Drive letters are messed up
PCI error appears to be connected to the onboard sound which isn't working
Help!
  • drsashorrosh Sep 04, 2008
    Thanks for the help. I agree with you that the drive letter really doesn't matter. What I really want to know is how do I access my data from my old drive. Is there software you can buy that will draw out the data without having to use Windows? (As you recall from my posting, the boot up sequence would get to the log in page for Windows then lock up. I have client accounts information I MUST get off the drive. By the way, I had Semantic's product loaded on that drive and when I access Rollback, the only dates shown are today's.
  • 3,940 Answers
To get Windows to recognize the 2nd HDD, you have to initialize it in disk management.
http://www.simplyguides.net/guides/prepare_second_hdd/prepare_second_hdd1.shtml
As far as the drive letter for the OS install, that was caused by the HDD not having an existing partition and other drives in the system having one (Either USB Drive, Printer with a card reader, 2nd Internal HDD)
Here is a Microsoft article on how to change it, but you'll notice MS doesn't recommend you try it. (Personally, I can live with ah HDD with a drive letter other then C:, so can Windows.)
http://support.microsoft.com/kb/223188/en-us
In the future, when installing XP, boot to the CD, run the install to the point of formatting the hard drive. Once formatted, turn off the computer, reboot to the XP install again, the HDD will be assigned C:
As far as the drivers go, they needed to be installed in this order:
Desktop System Software
Chipset
Video
Audio
Network
Modem
Posted on Sep 03, 2008
  • IQUIT Sep 04, 2008
    Once you have the 2nd drive assigned a drive letter in disk management, you should be able to browse the drive and access the needed files. you may need to take ownership to access the files.
    http://support.microsoft.com/kb/308421/e...
    If the files are encrypted or compressed in the OS of the old drive (the OS not being booted to) then they will not be accessable.
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Pavillion P6000 won't recognize any drives
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Want to connect 2nd sata hd but only 2 motherboard connections
u have sata connector. use this connector and power connector . switch on u r system it show drive.
or use extinal case
Mar 23, 2010 | Intel Motherboard
Motherboard won't recognize SATA DVD drive.
make the dvd your 1st priority in bios for boot, if it cannot be recognized try taking the floppy cable out of the floppy drive, maybe you have a problem with your power supply
Feb 14, 2010 | MSI K8T Neo-FSR Motherboard
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Essential 500GB isn't recognized by XP
What do you have them plugged into?
Make sure they are actually plugged into their power supplies.
(I know it sounds silly, but it's sometimes forgotten.)
Also check the power switch on the back of each drive. Press it to power on the drive.
Mar 29, 2008 | Western Digital My Book Essential Edition...
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
1,470 people viewed this question
Alun Cox
