Computers & Internet Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed cmos battery 2 time but problem is same date & time is not saving so iwant solution regarding this problem
PNiss
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Mar 29, 2011
PNiss
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
60575
Points
379
Hello vikasshar206:
Are you sure you are saving the settings in the Bios before you exit it?
If that's not the problem then make sure you are using a brand new battery (I have gotten bad brand new batteries before so that's why I mention it) for the motherboard and also check to see if there is a jumper setting that will reset your Bios. You will have to check your motherboard manual to find the cmos reset jumper location.
Your FixYa Team member Peter N.
Packard Bell BL 2141 Q660, Denver 10 Motherboard. I Cannot set DayDate in CMOS
check if your clock battery on motherboard is working properly
1helpful
2answers
My date is not getting set in bios
Change the CMOS battery.
If you had taken the time to post the computer manufacturer name, and model number; I would know what motherboard we're dealing with, and what type of CMOS battery it uses.
Generally the battery is a CR2032.
A type of watch battery.
Positive ( + ) side ALWAYS goes UP
Post back in a Comment.
Regards,
joecoolvette
P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
If your cmos battery is new and the date and time not change. Try the following.
1. Clean the cmos battery terminals.
2. Check your mother board if there is bulges capacitor.
3. Check the memory you have using if in the same voltage requirements.
Hope this will help to you.
I set date & time on my acer aspire, but it will not stay set it just stays on the date & time ive set. help! fred.
Welcome to FixYa!
-try doing these steps.
1) Enter the CMOS setup
-to enter the CMOS or BIOS setup, shutdown the computer completely -then once you press the power button to turn it on, keep on tapping on F2. (for some computer its F1, del, F10)
2)In the main or system setup screen you should be able to see the date and time. Using your arrow keys, navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
These steps may vary for your BIOS; additional help, information, and simulations can be found on the BIOS help page.
3)after you have configured the time and date, save your settings and exit.
4)if it still would'nt hold the time you have setup, it could be a possible virus issue, or the CMOS battery on your computer could be degraded.
Hope this steps would help!
Have a great day!
2answers
System Time and Date Change
It is because of CMOS battery is weak
Change it and it will be fine
I could not save the system time & date. The time & date remains till there system is not rebooted. After reboot it changes time again
The most possible cause for that is the cmos battery at the mainboard. Open the case and try to locate a round small battery like this
Remove it and using this as a sample buy a new one (it's about 2-5Euros cost). Repalce with the new one and you are ready. After changing the battery a good advice is to get into the bios settings and check them, because sometimes are resetting at default after changing the battery.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
2helpful
2answers
Every time i switch my acer aspire on it goes back in date and time to 2005 ..i have changed the battery on the motherboard to no affect..help!!!!!!
You just set up the time in BIOS setting. To get the BIOS just press delete during your laptop is on. Go to CMOS to change the time. Use arrow key to select after that you need to save just press F10 to save settings.
5helpful
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
3answers
Cmos checksome error
I don't know what kind of unit you are useing.
You need to watch the screen when it boots up.
It will say check sum error, press ? F-2 to continue or F-1 to enter setup.??
Enter the setup screen and change the date and time.
Save ? F-10 and exit.
I hope this has helped you.
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Grand Canyon Tech
Grand Canyon Tech
