Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I need help
Wd-62525 led does not stop blinking?
DM board NLA.
FMT board NLA.
  • 927 Answers
Good Day, RONALDSADAT;
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Posted on Aug 05, 2008
SOURCE:
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light on wd-62725
Test the caps on the power board. tell me if the led is bloinking a number of times.
Oct 24, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Have you tried the reset button on the front of the tv, on the far left I believe? That probably won't solve your issue since this has been an infamous problem for Mitsubishi.
If the reset button doesn't work the most probable fix are the (12) 1000uF capacitors (4 on each board) on the Power Supply, FMT board and the DM board. There are several other replies from reputable repair people on this site for this problem on the wd-xx525 series.
You probably just need to replace the DM capacitors. You can get the V26 DM repair kit from www.tvrepairworld.com which has the capacitors and the Cd with instructions
Jan 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The green timer lite is blinking and the tv will not turn on. It's a Mitsubishi Medallion we bought about 5 years ago. It has a 64 " screen from corner to corner. This didn't match any option I was given...
Good Day,
You have a couple of problems.
(LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002).
(LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A
(LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). .
I would not attempt to do this on your own! Call an Autorized Service Center, it wikll cost at least $ 750.
Dec 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
How do I check error codes on a Mitsu WD 62525. The set has been flashing green for 2 days. I tried to push and hold the menu and device buttons, but am not getting 2 different short codes. It seems to...
Don't need error codes for this one if the green light is flashing all of the time then you have a bunch of capacitors that have gone bad on the power board, dm and fmt boards.
Nov 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Code 1 2
Do not buy any board before tride this.
#1 replaced capacitors on power board-DM board and FMT board.
#2 1000mf x 16 v.
#3 total caps 12.
Sep 11, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 62525 honeycomb pictues
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
