Question about HP Photosmart 735 Digital Camera
When using the flash, camera shows charging flash and freezes up the camera
  • poulter Aug 21, 2008
    got a new photosmart r707 every time take picture with flash states charging flash and freezes up camera can someone help.
  • felixananaba May 11, 2010
    how do i solve this problem
I contacted HP tech, after trying several resets and other setting changes, I was informed that it would cost more to fix the camera then its worth - No longer under warnaty.
I can use the camera as long as I disable the flash.
Go out a buy a Canon, I did and its a lot better camera.
Posted on Oct 06, 2008
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Tip
How to detect a defective remote control?
kindly use a digital camera.put it in front of television remote control while freezing the bottoms anywhere.A good condition shows the LED sensor flash" while freezing it.A defective remote control indicates no flashing of LED.
this is very simple.
/images/fixya3/answer/vid-placeholder.png this video shows an ok remote control''
on Aug 25, 2010 | Televison & Video
Camera freezes after one photo
Its for flash. Flash capacitor is not charging properly.You off flash than check it will work properly.
Jun 05, 2012 | Nikon S205 Digital Camera
Whyb when i use the flash off mode are my pictures blurry
The flash duration is so short that it literally "freezes" all movement. With the flash off, any movement from you while clicking the shutter button will show up as blur in the pictures. If you can't hold the camera steady, consider buying a monopod or even a tripod. Or better yet, get a camera with built-in image stabilization.
Jun 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Received Kodak 8.1 last April. Now it freezes
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 05, 2010 | Cameras
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Busy when i use the flash.
The capacitor in the flash circuitry needs to be charged to a before the flash can be fired. This chargeing time is termed as flash recycle time and duriing this window the camera wilkl show that it is 'BUSY'.
Mar 23, 2009 | Canon EOS Rebel XSi Digital Camera
Flash Problem
there is no chance you can fix it.. you need prof service to fix it. internal flash circuitry malfunction is present. try shooting in program mode or manual setting ( not using flash).
Jun 05, 2007 | Olympus Stylus 710 Digital Camera
Camera Freezes Up
Sounds very much like a faulty camera. Check that all controls are as they should be, then if it persists your best bet is to have it replaced under warranty.
Sep 13, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
HP Photosmart 735 Digital Camera Logo
95 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
