I have MSI K8MM-V N1996 motherboard when i am going to install winxp sp3 i doesnt install and shows the message that No Hard Disk installed. Windows 7 and Vista is working fine. but i want to install winxp only please let me know how the rid out of this problem.
If you are trying to install Windows XP and it does not detect the SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and
raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
First of all never update or install the new bios.. plz let it be geniune .. another thing is that you have to now do the following which might help.. not sure but should
Open the case
look for the jumper on the mother board.
when found take it out
and the reboot or boot your machine
then check if bios options and windows have started
if windows does not appear then install new OS recommended windows 7.
after this plug the jumper back into the motherboard back.
Now this won't work then it can posibly have damaged you motherboard...
Hi, at the boot up go into your bios
[ on MSI press the delte key continuosly] and turn OFF the onboard virus protection. This can block all O/S from loading as they need to write to the bios in the installation process.
Ensure you turn it back on after installation, it is there to stop hackers getting into your bios and wrecking your system.
Regards mistyman
