Audio is fine, but video will off after 5min ON time
My TV after turn on all will work fine for first 5min. then the screen become blank but audio and channel change are work fin.
  • 1 more comment
  • howac506 Aug 05, 2008
    Hi Sir;
    Thaks for responce. Here are the informations you listed.
    1) My TV set is Mitsubishi VS-4507R Rear projection TV.
    2) Before the picture goes out, it was nothing happen, the picture just goes suddenly.
    3) No front panel light.
    4) The sound is caome from TV. I did not hook with anything.
    5) I connect direct to the cable. but no cable/sat. box.
  • howac506 Aug 07, 2008
    Thanks! I will try it. Dos this IC is LA7838
  • MICHAEL MULLINS May 11, 2010
    Good Day, howac506;
    Okay, no pic/has audio after 5 minutes, this is a very generic concern. Let me ask you some questions and make some suggestions so maybe we can solve this problem:
    1. What brand and model number is your TV? (small paper sticker on rear of TV)
    2. Does the picture do anything before it goes out? (turn a color or lines etc.)
    3. Does any front panel lights blink? (how many & which ones)
    4. Is your sound from the TV or stereo?
    5. Do you have cable/ sat box?
    Sorry, I was not helpful this day but give more information and I will help you as best as I can.
    Thanks, big IRISH. ps Too many TV's and types (dlp, lcd, rear projection), again, sorry.
Hi;
Thaks! I will try it.
Posted on Aug 09, 2008
  • 927 Answers
Good Day, howac506;
The most common problem for your 1991 TV is the vertical out put IC (IC) part number 272p239040.
I hope this was helpful.
Good Luck again, big IRISH.
Posted on Aug 06, 2008
  • MICHAEL MULLINS Aug 07, 2008
    LET ME KNOW IF THIS HELPFUL.
  • MICHAEL MULLINS Aug 08, 2008
    Good Day, howac506;
    Like I stated it more than likely the vertical out put IC but here is a more detailed way to trouble shoot and repair of your TV:
    SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2. WITH VERTICAL PROTECTION DEFEATED (D4A1 OUT OF CIRCUIT) WHEN THE UNIT POWERS R514 (PIN 11 OF THE FLYBACK) OPENS. CHECK PARALLEL CAP. C512 .33 UFD 400 V IF C512 IS GOOD REPLACE THE FLYBACK PART # 334P191020 ON THE MAIN PCB. 3. CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 (PART #264P487030) LOCATED OFF PIN 1. (PCB-MAIN) 4. CHECK PIN 8 OF IC401 FOR 28.4VDC. IF MISSING CHECK FOR OPEN D520 AND R540 AT PIN 5 OF FLYBACK TRANSFORMER T503. (PCB-MAIN) D520 PART #264P102020 R540 (1.2 OHM 1/4 W) PART #103P398010 5. CHECK FOR DEFECTIVE IC401, PART #272P239040 ( PCB-MAIN) 6. CHECK R540 1.2 OHM 1/4 W OFF PIN 5 OF FLYBACK (PCB MAIN). 7. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT.
    Good Luck, big IRISH.
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
I have a Panasonic TH-58PE75U, that I purchased Nov. 2007. Yesterday it was working fine; however, I left the room and returned. The screen was completely dark (out), but the audio is working fine. I...
When you turn the plasma on do you get a solid indicator light on the front of the tv? You also get sound just fine, but a blank screen and no picture. I'm still looking for a definite answer, but I repaired a Hitachi 42edt41a that had the exact same problems. On that plasma there was an X-sustain board and a Y-sustian board that needed to be replaced. Hopefully someone else can give their assistance as well.
Dec 08, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
60" plasma TV video turns off
I just unplugged the TV for a minute and then plugged it in again. It works fine.
Apr 05, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
