Question about Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Printer
After replacing all the ink colors, we are now getting horizontal streaking. We have tried aligning the new cartridges and cleaning, but are still getting the streaks. What can we do?
  • btracy1020 Sep 08, 2008
    Turn the printer off then on again.
  • Gerry Millward
    Gerry Millward May 11, 2010
    It's a long time now without any help forthcoming on this problem. Can you post a new comment updating the situation, so that I can try and help you fix it, or close it as solved!
  • 353 Answers
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles recently? If not, do it. Then do a nozzle check print. Any improvement? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 01, 2009
I just changed all the cartridges in my epson stylus sx12 but still says theyre empty
p { margin-bottom: 0.21cm; }
According to your problem first make sure that you have installed the cartridges properly. Go the the printer properties in control panel and follow the steps open the printinging preferences tab> maintainance tab > Ink cartridge replacement> then the window will show the process of the replacement of ink cartridge. Follow those steps of replacement. Then let the cartridge be processed, it will take a few time. And then your cartridge replacement will be finished. Then align the cartridges from the alignment option in printing preferences as well. If it doesn't solve your problem then the cartridges are faulty, replace a new set of cartridge is recomended.
Jun 09, 2011 | Epson Stylus C88 InkJet Photo Printer
Recently replaced all cartridges in C88 with new recently purchased Epson cartridges. Only blue and black ink prints. No red or yellow. Tried cleaning printer heads. Still no red or yellow printing.
You have to go to the properties of the printer and in the maintainance tab do some nozel cleaning and head cleaning.
and check it should be fine
thanks
Dec 14, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Replacement of ink
Hi,just go to the printers properties select maintainance select status monitor from there the procedure is self explanatory,try that.
Jun 15, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Apr 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Changed the black ink on epson c88 and it will not print
Unfortunately yes... you need to have at least some ink in each cartridge or the printer will refuse to work.
I did post up a long explanation of why this was on another solution but I can't find it so short version is that it does this to stop damage to the printhead nozzles.
Hope that helps.
Mar 18, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 no longer will print colors
you mean it goes intothe motion of printing and the paper comes out blank ?
you already changed the cartridges and performed print head cleaning. it is having a hardware failure and it needs service. (get a new one instead)(contact the manufacturers customer service and ask for the loyalty program - discounted price)
sad to say but theres no fix-it-yourself for that issue. (you can verify it with the manufacturers tech support)
Nov 14, 2008 | Epson Stylus C88 InkJet Photo Printer
C88 only green and yellow
You are out of black and magenta (tricolor cartridge) ink or ink has dried up.
Try touching the nozzle plate (underneath print cartridge) with a water dampened cloth (not alcohol) for cleaning clogged nozzles (do not rub).
Ultimate remedy : put in contact nozzle plate with hot water for about 5 seconds.
If color still missing your printer need new cartridges.
Jan 06, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
