Question about Canon imageRUNNER 1023iF Black and White Copier
I have a Canon ImageRunner 1023iF copier/FAX machine
The "Processing /Data " Green light stays on. I think it happened after a failed FAX attempt. I cannot clear it, the machine has plently of paper.
Please Advise;
Carl Patturelli (617) 525-7592
[email protected]
    Problem Solver:
  • 12 Answers
Check view setting button to see if any jobs are pending if so you can clear them in there, try unpluging the machine for a few minutes if none of this work it could be the main board
Posted on Aug 13, 2008
SOURCE:
Canon ImageRunner 1023 copier keeps making a clicking noise after I hooked it up to the phone jack to fax
first did You connect the tel. line in the jack where is marking L ? if not connect it.
Try to connect the plain telephone on that line and try to dial somebody to see if the line is OK.
... In most cases when the machine starts to produce the click sound it means that the fax board is defective and you need to change her.
Regards.
Jan 07, 2011 | Canon imageRUNNER 1023iF Black and White...
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on [email protected] with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
Jan 13, 2010 | Canon imageRUNNER 1023iF Black and White...
I need to change the date on fax confirmation pages to the current date on a Canon ImageRunner 1023iF.
1)Press the Additional Funktion button.
2)Press the arrowkeys untill 6 TIMER SETTINGS is displayed Press the OK KEY
3)Confirm that DATE TIME SETTING is displayed and press then the OK key
4)Change the date and time
Aug 19, 2009 | Canon imageRUNNER 1023iF Black and White...
Adjust volume canon imagerunner 1023iF
Press "Additional Functions" button. <common settings> should be displayed, if not press the "+" or "-" button until common settings is displayed. Press "ok". Press "+" or "-" button until "Audible Tones" is displayed. Press "ok". Walk through this submenu to locate the fax volume. Press "ok". Adjust as needed. Press ok. Press stop to exit settings mode.
Aug 13, 2009 | Canon imageRUNNER 1023iF Black and White...
Fax to email on a Canon imagerunner 1023if
Do your company have a mail server and wat is its ipadress?
Feb 10, 2009 | Canon imageRUNNER 1023iF Black and White...
Cannon Image Runner 1023iF will not send or re: a fax
First try to check your fax settings.Your 'line settings' has to be set to 'tone' and not "pulse".
Set your fax mode for "fax only"
And try again.
Jan 20, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon imageRUNNER 1023iF Black and White Copier Logo
328 people viewed this question
Clive
Clive
old marine
old marine
Ekse
