Question about Xerox DocuColor 12 Printer
Flashs L then flashs 6 back and forth
Model is xerox XL2130f Thanks for your help.
    President:
  • 2,072 Answers
L6 Polygon motor (drives the laser) problemMost likely the laser has failed.
Posted on Aug 04, 2008
Automatic feed does not work
The wheels that are supposed to grab the paper might be dirty or broken, the reason can also be that the sensor that should see the paper doesnt work for some reason.
Nov 14, 2011 | Xerox WorkCentre XL2130f Laser Printer
How to remove glass on dell 948
You have to lift the document feeder up and out of the slots in back.
I would also recommend removing the screws from the back cover and taking it off. Then take the two front screws off on the top holding both the ledt and right top covers. Remove those covers, and also remove the one screw holding on the plastic strip along the back of the glass.
Then remove the glass. Be careful cleaning the scan head. That lamp is very fragile.
Dec 30, 2009 | Xerox WorkCentre XL2130f Laser Printer
Diagram of how to remove a exploded toner
Compressed air and a toner vac. You might need to remove the platen glass and clean up under there as well.
Jul 11, 2009 | Xerox WorkCentre XL2130f Laser Printer
L 6 code flashing
That is a laser fault. Normally the motor that turns the mirrors in the laser assembly is failing.
You can also try this. take the back off the machine, there is a ribbon cable attached to the main board that I have seen unplugging and re connecting resolves an L6.
about the best price I have seen on that laser is about $300.
Google a business called "the parts drop". You can look up the part and price there. Honestly, that is one heck of a job replacing that laser. You pretty much have to split the machine in half to replace it.
Mar 02, 2009 | Xerox WorkCentre XL2130f Laser Printer
Shut down at 18,000 pages, J2 code
that is the exact life of a drum for that machine.
Feb 20, 2009 | Xerox WorkCentre XL2130f Laser Printer
Workcentre XL2130f does not ready itslef sometimes
Normally when that happens the machine need a general cleaning. Also take the toner cartridge and shake it side to side to be sure there is enough ink where the density sensor is.
There is a light on the machine that will start flashing when the drum has about 500 pages left on it.
What you most likely have to do is take the toner cart and drum out, clean in that area well, Take a flashlamp and cloth dampened with some alcohol and clean any sensors , lamps you see. Also look to the left, you will see an opening about 1/4 of an inch high and 6 inches wide, That is your laser window. You want to take. most likely a Q-tip and clean that glasss inside that slot.
On thre right side door there also is a tranasfer wire, it is in an opening in a metal bracket that will need cleaned. Be cautious since it is a very thin wire. Dampen a q - tip with alcohol and gently wipe back and forth to clean that wire.
Then remove the screws around the glass, lift out the glass and clean the underside of the glass , lamp and mirrors.
The XD2130 is really a good machine, if you don't remember repalcing a drum on it, then you must not have a very high volume on it, I would even pay someone to clean it for you if you like.
Xerox doesn't service it any longer, but parts and reputable people still service those on a daily basis. Its a good machine,
Jan 13, 2009 | Xerox WorkCentre XL2130f Laser Printer
Driver for xerox worcstation xl2130f in vista
Im afraid you wont do either. Fiery have washed their hands of this old boxes now
Oct 26, 2008 | Xerox DocuColor 12 Printer
Xerox workcentre Xl2130f copier printer error j1
that is the message for low or out of toner. What you are doing by tapping it is just lostening the reemaining ink in the cartridge. If the cartridge is new, have it replaced where ever you purchased it because most likely its defective.
Oct 02, 2008 | Xerox WorkCentre XD120f Copier
ERROR MSG CH
A CH code means the toner cartridge is not being sensed.
Could just be not seated properly. Open the front and remove and reseat the toner cartridge.
It may be empty also.
Aug 24, 2008 | Xerox WorkCentre XL2130f Laser Printer
Xerox work centre xl2130f developer
It goes in with the toner. The developer and toner mix in the cartridge. Empty the old out and put it in with the toner.
Good luck.
Feb 07, 2008 | Xerox WorkCentre XL2130f Laser Printer
Xerox DocuColor 12 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
